Guantanamo Posted November 12, 2009 Report Share Posted November 12, 2009 (edited) Bought some forks from somebody on these forums. Trouble is the star nut they used is the wrong size for the steerer tube and has jammed in, and to make matters worse they've sheered off the bolt in the starnut. I've tried knocking the starnut through but being too big it's just wedged it. Any idea of getting it out? I asked in halfords if they'd drill it out for me, but they can't do it because of the sheered bolt. any idea? I don't need it out at the moment, but if i want to trim the steerer tube in the future (am running 30mm of spacers currently) i can't just put another starnut in on top as it's not wedged far enough down the tube. Make sense?Any thoughts appreciated.Adam Edited November 17, 2009 by Guantanamo Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 12, 2009 Report Share Posted November 12, 2009 Just drill it. Right through the sheered bolt. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 12, 2009 Author Report Share Posted November 12, 2009 Just drill it. Right through the sheered bolt.Went to halfords but they wouldn't do it for me and i don't own a drill. Thanks though Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 12, 2009 Report Share Posted November 12, 2009 They wouldn't do it? Ask anyone with a drill, you live in brum, i'll lend you one. As it's pretty much the only way you're gonna get it out! Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 12, 2009 Author Report Share Posted November 12, 2009 They wouldn't do it? Ask anyone with a drill, you live in brum, i'll lend you one. As it's pretty much the only way you're gonna get it out!Thanks, i'll try on yer bike, always been good beforeThey wouldn't do it? Ask anyone with a drill, you live in brum, i'll lend you one. As it's pretty much the only way you're gonna get it out!Think it needs trimming really? Quote Link to comment Share on other sites More sharing options...
King C Posted November 12, 2009 Report Share Posted November 12, 2009 Drill it out or man up and knock it out! Put a drift/large screwdrider down the other end of the forks and hit it until it comes out of the end it was put in. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 12, 2009 Author Report Share Posted November 12, 2009 Drill it out or man up and knock it out! Put a drift/large screwdrider down the other end of the forks and hit it until it comes out of the end it was put in.Tried knocking it out, just got so far then won't go any further. i'll get someone from my local bike shop to drill it for me. Quote Link to comment Share on other sites More sharing options...
dandadude Posted November 13, 2009 Report Share Posted November 13, 2009 (edited) Tried knocking it out, just got so far then won't go any further. i'll get someone from my local bike shop to drill it for me.With a few good hard hits using a lump hammer and a chisel/big punch it should pop out, the reason its jammed is its probably hit a small lump or cross binded. Give it some proper love and im sure it will pop out. Im sure your local bike shop will sort it out fine its just something like that im sure you could beat out yourself.Dan Edited November 13, 2009 by dandadude Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 13, 2009 Report Share Posted November 13, 2009 They are made of pretty 'hard' steel, which means they are brittle - so if you give it some grief with a hammer and a screwdriver (tech) it will fall to bits and drop out Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 (edited) They are made of pretty 'hard' steel, which means they are brittle - so if you give it some grief with a hammer and a screwdriver (tech) it will fall to bits and drop out believe me, i've been hitting it. Hard. doesn't look like the starnuts you supply with the circular nut area. this one looks like a normal 6 sided nut with the outer pieces bent right up against the steerer tube an the nut piece so close to the sides of the tub they may as well be touching. think i'll take them into the bike shop. Bummer. Edited November 13, 2009 by Guantanamo Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 13, 2009 Report Share Posted November 13, 2009 Any chance of a pic? Doesn't sound like a star nut... Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 Any chance of a pic? Doesn't sound like a star nut...Here you are, can see the sheered bolt and just make out the 'leaves' of the starnut. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 13, 2009 Report Share Posted November 13, 2009 Yup, that ain't no star nut. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 Welded in nut?!no Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 13, 2009 Report Share Posted November 13, 2009 Yeah, really doesn't look like a star nut... are they V!Z/Trialtech forks? Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 Yeah, really doesn't look like a star nut... are they V!Z/Trialtech forks?viz forks, but the bugger who had them before my didn't use the proper topcap that come with the forks. you can see looking down the tube the leaves of the starnut but doesn't look right. doesn't help that there's a bolt sheared in thereYeah, really doesn't look like a star nut... are they V!Z/Trialtech forks?Might just leave it in there and run with the 30mm of spacers, its on a 24" bike anyway Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted November 13, 2009 Report Share Posted November 13, 2009 viz forks, but the bugger who had them before my didn't use the proper topcap that come with the forks. you can see looking down the tube the leaves of the starnut but doesn't look right. doesn't help that there's a bolt sheared in thereMight just leave it in there and run with the 30mm of spacers, its on a 24" bike anywayshocker I aint no bugger! It was my bros fault! TWAT!its only got a star nut on because the 1st time I tightened it up the allen head rounded. SO tapped a small star nut in, jobs a good un. But the thing thats in it is the star nut tool. told my bro to take it out while I done sumat, and he didnt tell me he broke it. So just wrapped em up and posted em. it should push back down a bit though. if you like send em back up (Ill pay) Ill sort it at work. where there a asortment of big hammers and drifts! Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 shocker I aint no bugger! It was my bros fault! TWAT!its only got a star nut on because the 1st time I tightened it up the allen head rounded. SO tapped a small star nut in, jobs a good un. But the thing thats in it is the star nut tool. told my bro to take it out while I done sumat, and he didnt tell me he broke it. So just wrapped em up and posted em. it should push back down a bit though. if you like send em back up (Ill pay) Ill sort it at work. where there a asortment of big hammers and drifts!I've been hitting it using a 500gm lump hammer still nothing, it's gone about 40mm and wedged tight. it's ok, i'll see if the bike shop can get it out. thanks for the offer though.shocker I aint no bugger! It was my bros fault! TWAT!its only got a star nut on because the 1st time I tightened it up the allen head rounded. SO tapped a small star nut in, jobs a good un. But the thing thats in it is the star nut tool. told my bro to take it out while I done sumat, and he didnt tell me he broke it. So just wrapped em up and posted em. it should push back down a bit though. if you like send em back up (Ill pay) Ill sort it at work. where there a asortment of big hammers and drifts! how many spacers were you running with? don't get me wrong, the forks are sweet! Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted November 13, 2009 Report Share Posted November 13, 2009 i think I had 15 or 20mm I don't like cutting forks. made a cock up one time... Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 i think I had 15 or 20mm I don't like cutting forks. made a cock up one time...I did that too! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 13, 2009 Report Share Posted November 13, 2009 ram an upright pole/screw driver in a vice, hold the forks upside down and twat in between the legs of the forks with a block of wood and a hammer Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 13, 2009 Author Report Share Posted November 13, 2009 Bought some forks from somebody on these forums. Trouble is the star nut they used is the wrong size for the steerer tube and has jammed in, and to make matters worse they've sheered off the bolt in the starnut. I've tried knocking the starnut through but being too big it's just wedged it. Any idea of getting it out? I asked in halfords if they'd drill it out for me, but they can't do it because of the sheered bolt. any idea? I don't need it out at the moment, but if i want to trim the steerer tube in the future (am running 30mm of spacers currently) i can't just put another starnut in on top as it's not wedged far enough down the tube. Make sense?Any thoughts appreciated.AdamIt's not gonna budge hitting it, I'll have to get it drilled or leave it there. Thanks though Quote Link to comment Share on other sites More sharing options...
Shaun H Posted November 13, 2009 Report Share Posted November 13, 2009 But the thing thats in it is the star nut tool.Tool steel will be an utter slut to try and drill through. Just a heads up for that one. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 17, 2009 Author Report Share Posted November 17, 2009 Bought some forks from somebody on these forums. Trouble is the star nut they used is the wrong size for the steerer tube and has jammed in, and to make matters worse they've sheered off the bolt in the starnut. I've tried knocking the starnut through but being too big it's just wedged it. Any idea of getting it out? I asked in halfords if they'd drill it out for me, but they can't do it because of the sheered bolt. any idea? I don't need it out at the moment, but if i want to trim the steerer tube in the future (am running 30mm of spacers currently) i can't just put another starnut in on top as it's not wedged far enough down the tube. Make sense?Any thoughts appreciated.AdamFinally go the busted starnut out. had to stick my finger into the forks and turn the broken tool out with my finger. Then bash the shit out of the starnut. Matt Gibson you're a lucky man!Thanks for the forks though, pleased with them.Adam Quote Link to comment Share on other sites More sharing options...
