joshlyd1 Posted November 9, 2009 Report Share Posted November 9, 2009 Hi all i kinda rode thought a big mud pit about 17" deep and it went into my BB5 on my dj bike , i cleaned it and sanded the pads and now it does not work at ALL , help me please i dont know what to do its a daily user and is used near busy roads every morning , if that makes a difference maybe exhaust fumes on rotor ? i dont know any help would be gratefully appreciated thanks Josh Quote Link to comment Share on other sites More sharing options...
davey1991 Posted November 9, 2009 Report Share Posted November 9, 2009 Hi all i kinda rode thought a big mud pit about 17" deep and it went into my BB5 on my dj bike , i cleaned it and sanded the pads and now it does not work at ALL , help me please i dont know what to do its a daily user and is used near busy roads every morning , if that makes a difference maybe exhaust fumes on rotor ? i dont know any help would be gratefully appreciated thanks JoshYou may have sanded a little bit to much of the pads, also with sanding the pads you will have to let the break bed back in again.It could also be grit or exhaust fumes contaminating the pads and rotor, give it a couple of rides and if all else fails get some new pads. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 9, 2009 Author Report Share Posted November 9, 2009 I have done this on saturday and can ride my bike with the brake on , none stopping power whatsoever , i pooing my self jus rolling stops :/ Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 9, 2009 Author Report Share Posted November 9, 2009 Anyone please i need this done asap Thanks Josh Quote Link to comment Share on other sites More sharing options...
FINDUS Posted November 9, 2009 Report Share Posted November 9, 2009 Can you see the pistons moving?? maybe you have a leak? damaged seals from the crappy oil in the water?new pads, new rotor and a big long hill to roll down with the break half on, its bed in time they say about 20 hours to get really bed in. Quote Link to comment Share on other sites More sharing options...
Token Posted November 9, 2009 Report Share Posted November 9, 2009 ^ hopefully he hasn't got a leak with a cable disc. Sounds like they need bedding in on a long run with plenty of water being chucked on them at every opportunity. Quote Link to comment Share on other sites More sharing options...
FINDUS Posted November 9, 2009 Report Share Posted November 9, 2009 ^ hopefully he hasn't got a leak with a cable disc. Sounds like they need bedding in on a long run with plenty of water being chucked on them at every opportunity.lol that would be strange ^^ but you never know im half asleep Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted November 10, 2009 Report Share Posted November 10, 2009 ride down a big hill, pedalling with the brake held gently on. Rinse and repeat until pads are worn back in. Quote Link to comment Share on other sites More sharing options...
pogo Posted November 10, 2009 Report Share Posted November 10, 2009 Josh fails agian. . . . Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 10, 2009 Author Report Share Posted November 10, 2009 ok i did this this morning for about 45mins in the rain i just held the brake on all around my paperound ... nothing still , its starting to piss me off now Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted November 10, 2009 Report Share Posted November 10, 2009 buy a new rotor and pads Quote Link to comment Share on other sites More sharing options...
Mr Bob Posted November 10, 2009 Report Share Posted November 10, 2009 I reckon itll be the rotor. If youve got any spares or borrow one of a mate for 1 minute and see if there rotor works fine. If it doesnt it could be both the rotor and the pads or just the pads so yeh, try this and if not do what adam said, get new rotor and pads! Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 10, 2009 Author Report Share Posted November 10, 2009 ahhh ok , adam do you have one of those torque keys thing star shaped ? i will swap rotors Quote Link to comment Share on other sites More sharing options...
davey1991 Posted November 10, 2009 Report Share Posted November 10, 2009 If he has no braking power its more likely to be the pads, i've had bb5's on almost every bike i've owned (ALOT!!!) and i've never had any rotor problems, but plenty of pad problems. Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted November 11, 2009 Report Share Posted November 11, 2009 Boil the kettle, pour it over the disc/caliper with the pads in and then go for a ride. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 11, 2009 Author Report Share Posted November 11, 2009 Will try the lettle idea i will report back Thanks Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 14, 2009 Author Report Share Posted November 14, 2009 Anyone , local lads ? Quote Link to comment Share on other sites More sharing options...
Skoze Posted November 14, 2009 Report Share Posted November 14, 2009 If you've tried all of the above and it still doesn't work, you've probably munted something. Geta good looka t it and check it all works, can you see anything contaminating the rotor? Is it all adjusted properly? Is anything broken? Quote Link to comment Share on other sites More sharing options...
davey1991 Posted November 15, 2009 Report Share Posted November 15, 2009 Just out of interest, is the calliper loose? This sometimes can effect it.Take the pads out, is the piston moving, if not thats your problem. (Is it called a piston on a mechanical?) May just need a good service. Check the cable it could be snapped or very loose, the avid levers are sprung so it may not feel as though the brake is loose.check the inside adjuster and its internals, is everything working? If not you can get replacements straight from avid.If all of this seems to be ok replace the pads and rotor then see what happens. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted November 16, 2009 Author Report Share Posted November 16, 2009 Thanks ladies Quote Link to comment Share on other sites More sharing options...
