aron.echo09 Posted November 7, 2009 Report Share Posted November 7, 2009 i have put new brake pads on my magura back brake andwhen i peddle the crank arm slightly knocks it but not too much, if i move thebrakes in they grind on the rim, any advice please? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted November 7, 2009 Report Share Posted November 7, 2009 you could take a little material of your pads, or get a bottomn bracket with a longer axle. Quote Link to comment Share on other sites More sharing options...
tmusson Posted November 7, 2009 Report Share Posted November 7, 2009 I had this problem on my 07 stock czar. As previously said a longer bb would cure it,but you can also take a couple of millimeters of material off your cranks with a grinder without reducing strenght to much Quote Link to comment Share on other sites More sharing options...
hdmackay Posted November 7, 2009 Report Share Posted November 7, 2009 Either,1) Buy pads with a smaller amount of material, or cut your current ones down.2) Get a new BB with a longer axle3) Get shorter cranks maybe.If you ride mod, 160mm cranks and a 127.5mm BB axle should be fine for any amount of pad life. Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted November 7, 2009 Report Share Posted November 7, 2009 Get a longer bb or cut off some pad material.Cutting off part or the cranks doesn't sound like a very good idea to me. Quote Link to comment Share on other sites More sharing options...
tmusson Posted November 8, 2009 Report Share Posted November 8, 2009 Your not cutting it,only slightly filing it down. Cant see it reducing strength much. Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted November 8, 2009 Report Share Posted November 8, 2009 Your not cutting it,only slightly filing it down. Cant see it reducing strength much.Yes. However I think most people would prefer not to reduce strength at all.Also if its where the pedal goes in that it hits this wouldn't work unless you grinded the pedal axle too which would make the pedal or cranks more likely to strip where the pedal goes in.A longer bb is the best idea. Quote Link to comment Share on other sites More sharing options...
Dannyvd Posted November 8, 2009 Report Share Posted November 8, 2009 I had the the same problem with my Kott ms2 frame. The best thing to do is buy longer BB. I didn`t had the change to do so,because my frame broke before I could replace it Quote Link to comment Share on other sites More sharing options...
bogdan_vtt Posted November 13, 2009 Report Share Posted November 13, 2009 (edited) I had the the same problem with my Kott ms2 frame. The best thing to do is buy longer BB. I didn`t had the change to do so,because my frame broke before I could replace itwoow, that`s an outstanding testimony about this situation, i head one like this on my zhi z3...but i resolved it with some used pads (the crank only rubbed my maggye)...thing is when they will die, it will be a dilema for me Edited November 13, 2009 by bogdan_vtt Quote Link to comment Share on other sites More sharing options...
aron.echo09 Posted November 14, 2009 Author Report Share Posted November 14, 2009 Thanks for the advice Quote Link to comment Share on other sites More sharing options...
tonyblythtrials123 Posted November 14, 2009 Report Share Posted November 14, 2009 id say take a bit of material away, new bb means having to get it put on, and spending more money . Quote Link to comment Share on other sites More sharing options...
braderzz.p Posted November 15, 2009 Report Share Posted November 15, 2009 i have put new brake pads on my magura back brake andwhen i peddle the crank arm slightly knocks it but not too much, if i move thebrakes in they grind on the rim, any advice please? I had this problem i just put a space over the bottom bracket behing the cranks then put the crank back on then done it up it work trust me ! Quote Link to comment Share on other sites More sharing options...
