onzaboy09 Posted November 13, 2009 Author Report Share Posted November 13, 2009 yes this is a pic of mineMy Onza T-compHow do you upload big pics like that? Quote Link to comment Share on other sites More sharing options...
JT! Posted November 13, 2009 Report Share Posted November 13, 2009 Oh ok then, those tugs i linked you to are only for the newer onzas, i think your onza is 2007, maybe 2008.These should do just fine.http://www.tartybikes.co.uk/product.php?pr...p;category_id=8But you could just buy some replacement bolts. To embed pictures use the 'insert image' button. Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 13, 2009 Author Report Share Posted November 13, 2009 on my first onza i used gusset chain tugs which i found are stronger, would you reccomend these? Quote Link to comment Share on other sites More sharing options...
JT! Posted November 13, 2009 Report Share Posted November 13, 2009 It doesn't really matter, the only reason I suggested the onza ones is because they're for an onza and you'll have less chance of having problems with them fitting. (Although any chain tugg should fit fine).I've never known anyone to break a chain tugg so strength isn't an issue.Also it seems that the t-comp has a drilled hole on the dropout for snail cams, so you could look into those. The hole is for the bolt that the cam with push against. http://www.tartybikes.co.uk/search.php?category_id=114 Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 13, 2009 Author Report Share Posted November 13, 2009 What has best reliability chain tugs or snail cams? Quote Link to comment Share on other sites More sharing options...
JT! Posted November 13, 2009 Report Share Posted November 13, 2009 Well snail cams can't really go wrong as they're just a slice of spiraling metal with teeth, and a bolt that you screw into your frame and forget about. But then again tuggs are easier to use, especially since you've never used snail cams before.I'd stick with the tuggs seeing as though that's what you're used to dealing with. Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 13, 2009 Author Report Share Posted November 13, 2009 Well snail cams can't really go wrong as they're just a slice of spiraling metal with teeth, and a bolt that you screw into your frame and forget about. But then again tuggs are easier to use, especially since you've never used snail cams before.I'd stick with the tuggs seeing as though that's what you're used to dealing with.ok will do Quote Link to comment Share on other sites More sharing options...
