T-pro Crisis!
willis-gu
So basically i have cracked my t-pro and the crack is getting bigger and i can feel it when i ride. So i was just looking for advice really.
If i drill each side of the crack, it will give the crack no other place to go right?, other than to start a fresh crack at the other side or the hole which will take time.
Do you think this will make it last longer, or weaken it even more? Advice will be great cheers
:P
well....
my mate had a koxx kenny thing, and it cracked in 4 places, he drilled each side of the cracks and it never started cracking in the same place, it then cracked on both dropouts and he couldnt drill them out, so it eventually snapped there, so it will work, but you will have some horrible noises and flex coming from your frame, this also had a flat downtube, was the most abused frame i have ever seen, and from a koxx it lasted nearly 3 years, with alot of heavy riders :P.
so it will work, it'll just be gross :P and will probs crack in a different place in 3-4 months :).
  A.Baxter said:
is it bigger than it was the other day when when you mentioned doing this ? I reckon when it was the size it was then it might of helped depends how big it is now i would of thought.
Adam (Y)
have not been riding sinse really lol apart from 1hour today, its not much bigger like
  Mat Smith!! said:
:P
well....
Yeah i just need to save for a new one, just need it too last me. Its in a bad place really its on the weld on the gusset which is at the top of the down tube? if you get me lol
Yeah, they all snap there, my mates went there aswell, his didnt cover half the tube though, it was about an inch long and it lasted ages, well the headtube didnt fall off, the dropouts did about 4 months after it cracked there :P.
Drilling it gives the crack nowhere to go soit should be alright. Just make sure you don't go mental and put some hefty inch wide holes in there or anything. Just bear in mind that depending on how big the crack is it might be too late to really do anything about it...
yeah i have one in the chain stay too, but i cant here and crunching coming from that area yet, so think that might last a bit longer than the DT crack haha
yeah yeah, just small holes, hopefully it will be ok suppose we shall see
