How Long Spokes Do Pro2s Need?
LordMersey
Unless the flange spacing between your old hub and the pro2 as well as the flange diameter being the same its unlikey the spokes will fit. Measure these details up aswell as knowing the ERD of the rim and use the DT Swiss spoke calculator or call tarty and in their infinite wisdom they will be able to tell you whether it will work or not.
