Hope Straight Pull Hub For Trials
T.McMillan
64 members have voted
  1. 1. Do you fellow trials riders think this well be a good idea?
    • Yes
      14
    • No
      33
    • Maybe
      17
What would also be nice touch with the Pro2t, would be the option to use the hub with or without snail cams. I.e. removeable spacers which would make the hub compatible with more frame/chain tensioning combinations.
I currently run a Pro2t in a frame designed to use snails. I've got it sorted with some chain tugs, but it's not pretty. I'd give my right nut to be able to use snails with my Pro2.
You don't have to run snail cams on the inside you know. Just swap the bolts around and shove them on the outside. Also if you have to you can drill them out.
I'd be disappointed with Hope if they decided to go through with this. It's a waste of time and a daft idea. If hope want to compete in the trials market they should be making things like new free wheels, high engagement hubs, rim brakes and maybe cranks.
+1
A good 72 engagement freewhell from hope with an aluminum drive shell to make it lighter.
High engagement 116mm hub- would be good for the BMX market also, not just trials.
Rim brakes, from Hope! what a fab idea!
f**k the cranks I'm just waiting for middleburn screwons.
  • Like 1
Ive got snail cams in my frame, with a pro 2.
Like it. Neat bodge ;) But something that doesn't mean your frame spacing is forced apart would be great. Essentially, being able to use off-the-shelf parts is the point. (Y) Not everyone will be willing, or able, to faff about getting their bike working. I love a bit of bodging, but let's face it, most people just want to ride their bike rather than feck about with it.
Hope cams would be rather yummy too :D
Not on mine with its bloody fiddly drop-outs :D
  • 3 years later...
I'm sorry for, as they say, bringing this thread back from the dead, but I was looking on the Hope website today at work for a new hub shell for my Pro 2 and in the exploded diagram, there was a replacement option which uses straight pull spokes.. So I googled it and this thread came up.
I was just wondering has it gone into production as an option to upgrade them to straight pull now? I've seen the Pro 3 uses straight pull spokes but I've never seen the trials hub with them!
This is the diagram I'm talking about. http://www.hopetech.com/webtop/modules/_repository/documents/PROIIEvoSS-Trialexploded1.pdf
Cheers
Joosh
Tom posted a picture of his Ashton with a new proto hub on but the picture isn't very clear.
I presumed it was a hub with more engagements but maybe its the straight pull version.
http://sphotos-d.ak.fbcdn.net/hphotos-ak-ash3/35528_10151480006547889_1083463985_n.jpg
Edited by CalopS
I run Pro 2's on my trials bike and my mountain bikes but I've never been enamoured with their full build wheels as there's not enough rim options in my opinion. If this is an issue in the MTB world then it's only going to be worse surely in trials? Will there be straight pull builds in both 24" & 26"?
Also I've read a few different reviews that say the straight pull builds loose tension fairly quickly resulting in baggy wheels. I've never experienced this as I use the traditional hubs in custom builds but if they do loose tension over a traditional hub then what is the benefit?
I can see why Hope aren't rushing ahead with a 116mm Pro2. In the grand scheme of things how many are realistically going to be sold vs how long it'll take to develop? I'd be interested to see how the straight pull hubs turn out but I'm not convinced they're necessary, especially being sold in a factory wheel set only option.
I think the main benefit is that you have a spoke without a bend in it, making it stronger and less likely to break.
I believe the issue with them loosing tension is that the whole spoke can turn, so they can 'undo' them selves.
I've never had an issue with Hope hubs being weak in that area though, (I've only had issues with 12mm axles which isn't entirely uncommon) nor do I imagine many people have. I don't see it as an improvement if you can theoretically improve spoke strength slightly whilst making them susceptible to loosening?
I mean if it's a case of throwing the trials free hub on the already in existence straight pull hub shells then why not I guess, but in the very small world of trials I don't think a full build option is the way to go, especially considering most people who hop around I imagine run fixed hubs? Other than some 24" riders who actually uses Pro 2's anymore (in trials)?
  • Like 1
QUOTE (Al_Fel @ Nov 3 2009, 04:24 PM) <{POST_SNAPBACK}>
+1
screw on middleburns on pinkbike 1 of 6 made http://www.pinkbike.com/buysell/1220896/ sexy :giggle:
yes, there is a straight pull option shell on the hope parts list.
This is because the trials version is denominated SS/T as in single speed/trials and thus not specifically for us people.
I believe the straight pull Pro2/3 is more aimed at people like SS MTB nutters and hardcore/rich commuters who want a hub that can take repeated gate starts at traffic lights in high gears.
Edited by CC12345678910
yes, there is a straight pull option shell, because the trials version is denominated SS/T. single speed/trials
The straight one is aimed at people like SS MTB nutters, hardcore commuters and these hipster dicks on wannabe fixies (more interested in fairtrade coffee and looking like a tw@t in leggings than bikes or biking). You know the ones I mean... :sick:
any wiser??
Thanks to your post I'd imagine most are certainly not 'the wiser'. Especially considering what you said is nonsense.
Echo 108s undermine the need for a mod pro2. A matching set of hope hubs would be nice on a 20 but not a must have existing trials gear is better and cheaper than hope gear. Can this silly want for fictitious products please die?
if what i said was nonsense, i will edit and delete.
But it still made sense when I re-read the quote; or it does at least to me, although I was/am in a kinda mood, 'cos the urk in my college class was p***ing me the f**k off by his existence this morning.
excuse me peeps i'm off editing (and gonna put some more soothing music on :giggle:)
EDIT: any better??
EDIT 2:
You could say that about BMX kings, but people still spec 'em. Some even go to the faff on building a disc one.
I'd + a thousand for the mod pro 2.
