maxxis26 Posted October 30, 2009 Report Share Posted October 30, 2009 ok simple idea magura was getting lazy so decided to give it a fresh bleed with water...took it off bike, undo bleed screws pressed lever to start removing old water and the piston didnt come uphow to fix please people Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted October 30, 2009 Report Share Posted October 30, 2009 ryan that makes no sence. If the bleed bolts are out the piston wont move? Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted October 30, 2009 Author Report Share Posted October 30, 2009 the lever pistion is stuckits stuck as far down as it will go and wont return up Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted October 30, 2009 Report Share Posted October 30, 2009 undo the hose. Push it out with a 2mm allen key. Lube it up, away you go Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted October 30, 2009 Author Report Share Posted October 30, 2009 undo the hose. Push it out with a 2mm allen key. Lube it up, away you go no dont work cause im using new style lever! Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted October 30, 2009 Report Share Posted October 30, 2009 feck. Um the best thing i can think of is if you have a compressor, blow it out. Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted October 30, 2009 Author Report Share Posted October 30, 2009 FIXED IT used a syringe and stuck it in the end of the hose gave it a squeeze and the piston popped out Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted October 30, 2009 Report Share Posted October 30, 2009 sorted Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted October 31, 2009 Author Report Share Posted October 31, 2009 still have an issuenow it seem the piston doesnt want to move smoothly inside the lever it just gets stuck as i push it in...?not sure what to do? Quote Link to comment Share on other sites More sharing options...
nek0 Posted October 31, 2009 Report Share Posted October 31, 2009 You might want to bleed with mineral oil first to get some lube in. While the piston is pushed out also clean up around the piston really well and put Tri-Flow or similar thin lube around it. Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted October 31, 2009 Author Report Share Posted October 31, 2009 fixed it proper this time problem was the actual piston had exspended a little due tto grime building up on it after a little light sanding with wet and dry paper it slipped right in and returned the piston hitting me in the face...bleed it and re-set it up, no leaks from the sanding on the piston and it works a treat better then ever before Quote Link to comment Share on other sites More sharing options...
