Gear Ratio's
peggysue
i know alot of people seem to use 18 front and 15 rear on stock. ive always used 22tooth front and 18 rear. i have a tensile 96 click on the rear which is great but wanting to change my gearing slightly...
as i cant change the freewheel as most are 18 tooth .. would a 18 rear and 21 tooth sprocket upfront be the same as a 18:15..if so where the hell can i get a 21tooth chainring from? really want to buy some middleburn cranks with a tnn bash which fits the 5 bolt chain rings but they seem tomonly come in 20 or 22 tooth.
before anyone replies i dont want to run a front freewheel. it would mean having a screw on rear sprocket , which along with the freewheel would be an absolute pain to get off,as im a big lad and they really do tighten up very tight with my weight.
dont want to run a rear hub i.e hope pro or king...
just want to keep a freewheel on rear and try work around getting a slightly easier gearing, using middleburns and 5 bolt chainring. i could just simplt go for 20 tooth on front but thinkthat its probably far to easy gear?
god knows ... any advice?
I think that 22 tooth is the smallest 5 bolt chainring you can get. << Just read your post again. maybe you can get them in 20 :lol: Never knew that before :)
And also 22-18 is more or less the exact same as 18-15. << I'm quite sure about that though.
Edited by duncan_echo26
yeah tarty's do the middleburn rings in 20tooth... i would have thought 22 18 is 1 tooth heavier than 18 15 ratio... it dont feel the same on my mates bike... seems i can put the power through the pedals a little quicker with an 18 15 ratio...
18-15 is closer to 22-19 than 22-18. It's actually like the same as 22-19.4 or something lol. 18-15 is an easier gearing than 22-18.
Forget that, 18-15 is EXACTLY the same as 22-18(.33333333333333333333333333333) lol. It's 18-16 which is the same as 22-19.5 or so...
Edited by BringThatShtIn
It is not just the ratios, you also need to consider crank lengh, it would feel different not just "power" wise . I know few people who have 165mm with 18-18t or 18-17t or 18-16 with 175s and 170s. At the moment I am running 18-15 with 170 and that feels a bit hard, especialy on the rocks! So I wil go for 17-15 soon :) I know more old sch riders who run 1:1 ratios than anyone else.
That's actually a really interesting idea lol, I'd never thought of that, but it makes sense.
Still, 22-18 is the same as 18-15 to a third of a tooth...
strange.lol.
well i may just stick with the 22 18 if they roughly the same .
saves messing around.
cheers guys
Theyre not roughly the same, theyre almost exactly the same, take 22 and divide by 18 = 1:22 ratio THEN take 18 and divide by 15 = 1:20 ratio
I don't think you'd notice any differance.
Martyn
Martyn
Take 22 and divide it by 18.
Multiply 18 by the answer and you get 15.33333333333333rec.
So 22:18 is exactly the same as 15 and a third. That's how exact it is.
