315r Posted October 23, 2009 Report Share Posted October 23, 2009 Hello.I have 2 questions about brake levers blades.1st: I have a 4 fingers magura lever blade and a Echo blade, What is better? and How can I fit a Echo in the magura lever body? I Think that I need a extra washers to fit perfect but I don't know wich is the correct thickness of washers.2nd: How can i disassemble a magura louise lever blade? I have been reading all the documents in Magura web and don't explain well. My magura lever blade lose tension during the ride and i don't know what can i do. I noticed that the screw is loosened during ride....I have been used the "search" tool and I didn't find nothing, if it is a repost let me know...Thank you. Quote Link to comment Share on other sites More sharing options...
315r Posted October 24, 2009 Author Report Share Posted October 24, 2009 No idea? Please is important..Thank you. Quote Link to comment Share on other sites More sharing options...
nyoli Posted October 24, 2009 Report Share Posted October 24, 2009 hey !im gonna reply in catalan because we are and i'm gonna explain myself better.si vols k el freno tingui més tensió, has de treure la tapa de plàstic que hi ha al frontal de la maneta. Allà dins hi ha un cargol de cabota allen. Si el colles, la maneta té menys recorregut. Si la destenses, la maneta té més recorregut, però vigila no et passis, pk llavors kuan vagis am bici s'anirà descollant cada vegada mésspero k et serveixi d'ajut Quote Link to comment Share on other sites More sharing options...
315r Posted October 25, 2009 Author Report Share Posted October 25, 2009 hey !im gonna reply in catalan because we are and i'm gonna explain myself better.si vols k el freno tingui més tensió, has de treure la tapa de plàstic que hi ha al frontal de la maneta. Allà dins hi ha un cargol de cabota allen. Si el colles, la maneta té menys recorregut. Si la destenses, la maneta té més recorregut, però vigila no et passis, pk llavors kuan vagis am bici s'anirà descollant cada vegada mésspero k et serveixi d'ajut Thank you nyoli!But the problem it's just that this screw, like you said, loose tension during the riding.Now in Catalan: El cargol ja l'he tocat, peró estigui on estigui es destensa en cada ridding queda molt fluix i es mou del seu lloc, encara que no m'hagi passat...De les arandeles per la Echo saps algo?Thank you / Gracies. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted October 25, 2009 Report Share Posted October 25, 2009 The 4 finger blade is better but the echo should fit without washers as mine did. Quote Link to comment Share on other sites More sharing options...
315r Posted October 25, 2009 Author Report Share Posted October 25, 2009 (edited) The 4 finger blade is better but the echo should fit without washers as mine did.Ok, therefore, if 4 fingers is better, i left it in the bike. I though that echo was better because echo is CNC and 4 fingers no..Although echo don't fits well without washers for sure, I fit the same blade in my old monty magura and blade scratch in to magura lever body pump a lot, echo blade is thinner than 4 finguers blade.thank you!! Edited October 25, 2009 by 315r Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted October 25, 2009 Report Share Posted October 25, 2009 There both CNC are they not?But yeah 4 finger IMO. Quote Link to comment Share on other sites More sharing options...
315r Posted October 25, 2009 Author Report Share Posted October 25, 2009 There both CNC are they not?But yeah 4 finger IMO.No 4 fingers are not CNC.Check here magura blades, exist CNC magura blades but is not mine.http://www.tartybikes.co.uk/search.php?cat...amp;brand_id=57CNC is clearly different.Excuse me but: What does it means IMO??Thank you Dale Hill! Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted October 25, 2009 Report Share Posted October 25, 2009 No 4 fingers are not CNC.Check here magura blades, exist CNC magura blades but is not mine.http://www.tartybikes.co.uk/search.php?cat...amp;brand_id=57CNC is clearly different.Excuse me but: What does it means IMO??Thank you Dale Hill! Cnc = computer numerically controlled. Basically it's usually drilled from a piece of billet rather than forged. Quote Link to comment Share on other sites More sharing options...
315r Posted October 25, 2009 Author Report Share Posted October 25, 2009 AHAAA!Check please the CNC option.You can see that have something like a washer that Echo don't have!!This is the reason because echo need washers to fit in magura lever body pump. Quote Link to comment Share on other sites More sharing options...
315r Posted October 25, 2009 Author Report Share Posted October 25, 2009 Cnc = computer numerically controlled. Basically it's usually drilled from a piece of billet rather than forged.Exactly, this is the explanation.4 fingers are forged. and CNC drilled from a piece.anyway.Some solutions for alive screw in magura louise? Quote Link to comment Share on other sites More sharing options...
315r Posted October 26, 2009 Author Report Share Posted October 26, 2009 Well i'm trying to strike with a little hammer this screw, maybe becomes strong but is not the best idea...Somebody have the answer? Quote Link to comment Share on other sites More sharing options...
