Cleaning My Rim?
ogre
White spirit on the rim and clean it off with water. Then sand the pads down. But to be honest though. Your best option would be a re-grind.
Sure, the white spirit will work, But probably not as wel as a nice grind. Just grind the rim and make sure the surface of the pads are clean(Sand them down, Then get a new bit of sand paper and do it again. To make sure theres no oil on the sandpaper you were using to begin with) Then just set it up and get going.
White spirit leaves a film behind so don't use that - its why it can feel no better afterwards.
You don't need to regrind at all - thats pure overkill and stupid advice, you only got lube on your rim and you've only just ground yuor rim..........plus a new grind might not even get it all off so ignore that advice.
All your need is meths. It will break down the lube and clean the rim, also it will evaporate afterwards leaving nothing behind. Feel free to go a couple of times or even use some hot water afterwards but its a great method and works perfectly.
I'd have to agree with giving your rim another run over with the grinder.
Boys, I think he means the tyre residue - which is a total phantom b*****d on rims.
I gave the rim a regrind after trying fairy liquid and all that other stuff that didnt work, wiped the pads with a dry cloth and wha la, perfect again.
Re-grinding your rim isn’t such a drastic solution at all. It’s not like giving the rim surface a light going over is going to take a heck of a lot of material off!
To round up, if a jobs worth doing, its worth doing well.
CRC Industrial contact cleaner, dry in seconds, leaves no residue, multi purpose cleaner
I use this in work (Fixing diesel engines) and the electrical plugs can get oil/dirt in them and this stuff cleans it like new and has no effect on plastic,rubber,metals. I also use it to put grips on aswell, at max 1 minute the grips are dry and solid to use and wont come loose and i clean all my bike parts
PRODUCT INFORMATION
Industrial QD Contact Cleaner
Use in bench top cleaning applications requiring rapid turn-around time
Removes light oils, dirt, dust, fingerprints
Does not damage plastic
Extremely flamable
Self merchandising
