JTM Posted October 22, 2009 Report Share Posted October 22, 2009 I have HND level mechanics question to do on eccentric loading. It involves a metal sheet with 9 strain gauges along its centre, a load is applied at opposite ends putting the piece under tension, the question gives readings for the 9 gauges and wants you to work out what the "theoretical stress distribution" is across the metal using "simple bending theory".Ive been searching the net for a while, and im having no luck. Can anyone shed some light?Thanks Quote Link to comment Share on other sites More sharing options...
hI-OOPS-CAPS Posted October 24, 2009 Report Share Posted October 24, 2009 in simple tension the load applied will produce a stress which is uniform through out the metal, if its cross section is uniform anyway (the force will be in the centre of the dotted crosses). by eccentric loading i assume you mean the force is applied away from the centre. in that case youll get a bending moment which will pull the beam over to one side. where if you take the simple equation moment = Fd the distance is the from the centre to the applied force.to work with stresses though its sigma = My/I = Fdy/I if you know about bending with reference to a certain axis (its in y-y plane) then itll become sigma = M y^2 / I. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted October 24, 2009 Report Share Posted October 24, 2009 A visual representation of the problem would definitely help. As outlined above there will only be a bending moment if the cross section is not continuous or if the force is not applied central to the cross section. Quote Link to comment Share on other sites More sharing options...
