pizzapie.. Posted October 21, 2009 Report Share Posted October 21, 2009 I have my piston stuck inside my lever and dont know how to get it back out, its not on my brake at the moment.but i would like to put it on but my piston is stuck in how can i get it out?i dont have any long nose pliyers though so its realu hard to get out Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted October 21, 2009 Report Share Posted October 21, 2009 I take it your on about a HS33? If it is an 04 style poke a tiny (i think 2mm) allen key through the bleed hole and it will come out. Quote Link to comment Share on other sites More sharing options...
pizzapie.. Posted October 21, 2009 Author Report Share Posted October 21, 2009 I take it your on about a HS33? If it is an 04 style poke a tiny (i think 2mm) allen key through the bleed hole and it will come out. Sorry mate its on 05 Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted October 21, 2009 Report Share Posted October 21, 2009 I had same problem. Bleed screw all the way in, bleed hose in the other hole, attatch pump to other end of bleed hose, pump fast/hard. Point the piston away from everything valuable/that could be hurt though. Quote Link to comment Share on other sites More sharing options...
