Headset/star Nut
George.E
Baisically, I have an Onza Mongo 3 headset with Echo Lite forks.
There is movement that keeps coming in my headset, my star nut is almost 1cm deep in the steerer tube and isn't near anything at the top. I often have to loosen my stem bolts an tighten the top cap because of it coming loose, I do this around 4 or 5 times a day which has to be to much.
My star nut looks like its held in quite tight so Im not sure where I am going wrong.
Any advise would be greatful.
Thanks guys.
Thanks guys.
How long have you had the headset e.t.c
Was it profesionally fitted?
No they have all been in for quite a while.
mine did this, found some ball bearings were knackered thought it was them. Got a new headset put it in and still slightly wobbles, really annoyed me!
i dont know what was wrong with mine,
I don't have a mongo but do have a hope internal, one thing i found that helps a treat is a spacer that has a skinny end and a big end push push the skinny end on after you've slid your forks on facing skinny towards the bottom, and it works like a charm, but my headset was still before i did this, might work for you though.
There may be too much grease on the stem to allow it to clamp tightly enough on the steerer. This is a particular problem with stems that have a very long clamp on the steerer. Check also that there's a gap between the top of the fork steerer and the star nut cap - if there's no gap then it can't tighten more.
Edited by psycholist
I have just been out side now.
Does the steerer tube where the stem clamps onto need to be realy clean ?
And does the stem have to be realy tight when clamped ?
Thanks.
Yep and yes. But obviously dont overtighten so the thread strips/you shear a bolt.
max
Edited by trialsmax04
