Position Of Bars?
Ollied
There isnt a pacific way , its down to each riders preferance . the more forward the bars are gives a "tgs" feal while going further back give a "streety" feal.
Just ride your bike and make adjustments untill your happy with it.
So you don't have to cross an ocean to find out?
The further forward they're tilted the more stable it will feel on the back wheel, because it'll make you a bit more upright, if they're swept back it'll feel easy to pull up the front to manual but will be a bit sloppy feeling on the back wheel.
It all depends on your bike,the type of set up you already have, what bars you have and the style of your riding.
In general if you bunny hop a lot you should have them swept back slightly. If you do a lot of sidehopping, have them more forward, this makes it easier to pull upwards in the direction you're going when you sidehop. From my experience, it makes a hell of a difference.
I tend to go a slightly more forward but not too much. This way it's helpful for sidehops as well as tapping and other technical moves, where as having them set up simply for bunnyhops will make other moves a lot harder.
I generally just set mine up so that they're properly tightened, then just loosen the bolts off about a quarter turn each. Just stand over your bike and tweak the bars until they feel 'natural'. I generally don't bother messing around too much with the angle of them 'cos it just seems that when I'm comfortable riding my bike, everything feels fine.
OBM
