Ffw And Fixed Hubs
trialsmax04
my echo free hub has now skipped 5times in the last hour. It seams the harder i push it the more it wants to give up on me. My question is am i better off with a ffw and fixed hub combo? I would be on a strict budget, so i have been looking at the trialtech race on tarty. Any one tried these, and are they any good?
Also id need a ffw to go with it. My wallet tells me to go for an ACS Claw but i have heard horror storys about them. What would be a good budget free wheel? Is it also a sensible idea for me to get one second hand?
If i do this i will probably lace the wheel up myself. I have never tried it before, so is it wise i attempt it? Im fairly confident with mechanics ect.
Cheers fir help,
Max
If you can get the welded version of the ACS you shouldnt really have much of a problem. Thats what I was running back when I first started and it was fine up until I got a new bike. Never skipped or anything :)
If your on a budget get one.. However If you can stretch as far as getting a tensile or an echo TR get one ;)
And Building a wheel you should have no problems if you follow the guide on the wiki :)
yea thought so. The trialtech race will probably be the one. Although it runs on open bearings. I cant decide wether it would be good or bad. My echo freehub runs on sealed bearings and there expensive to replace and dont last too long.... I can see the pro's and con's of each.
DO NOT GET OPEN BEARING HUBS!!!
Sorry about that, open bearing are shit and will most likely break (with some exceptions in the form of the higher end shimano stuff, etc...). Also they are not nearly as smooth as sealed bearings, need more maintenance and are structurally weaker. Also I had a problem with the ACS on my bmx, where the outer ring was not very round, so dragged round the lockring, but that may just be the smaller thread ones.
As a general rule (from my experience, anyway) Echo sealed bearings are pretty shit - mine seized almost completely after 6 months.
Ahh not what i wanted to hear! In which case i could probably strech to a sealed onza t-master hub. Are thease any good? Really wanted to stay away from onza but if there good......
I rode with the open bearing trialtech hub for quite a while with no problems. It was a bit tedeous having to keep the cones at the right point though. If you are on a budget though it is ideal however given the chance i would ride with sealed bearings.
Get the trialtech and save some more money ready for your evo!!!!
haha legend! Defo need more money for that! So damn expensive. Is it you i have on my contacts on msn dauncy?
Technically a loose ball hub is the better, because it's better quality for your money, but the way it puts the load on the bearings is much less harsh than a cartridge bearing hub, it runs off the 2 o clock and 7 o clock axis rather than directly down (hard to explain) but yeah, cartidge hubs, because the way they're made allow a bigger stronger axle etc...
QFT
mine was fine? there is nothign to go wrong on them as it's all on the freewheel mainly.
