scotty007 Posted October 15, 2009 Report Share Posted October 15, 2009 Hi can any body tell me where i can purchase a hope freehub body from and if this will fit onto my halo combat rim as the bearings and pawls have died and given up on me thanks peeeeeeeeepss Quote Link to comment Share on other sites More sharing options...
David Biddle™ Posted October 15, 2009 Report Share Posted October 15, 2009 Hi can any body tell me where i can purchase a hope freehub body from and if this will fit onto my halo combat rim as the bearings and pawls have died and given up on me thanks peeeeeeeeepsshttp://www.tartybikes.co.uk/product.php?pr...category_id=148Hey Scott you need to check how meny spoke holes your rim is so you know if you need a 36h or a 32h.The other option is to keep a eye on ebay see if a full wheel build comes up.Biddle. Quote Link to comment Share on other sites More sharing options...
scotty007 Posted October 15, 2009 Author Report Share Posted October 15, 2009 http://www.tartybikes.co.uk/product.php?pr...category_id=148Hey Scott you need to check how meny spoke holes your rim is so you know if you need a 36h or a 32h.The other option is to keep a eye on ebay see if a full wheel build comes up.Biddle.THx biddle il check it out and give tarty a ring do you have to buy the whole hub or can i get the body sepratly seen it on chain reaction cycles so aint sure Quote Link to comment Share on other sites More sharing options...
David Biddle™ Posted October 15, 2009 Report Share Posted October 15, 2009 (edited) THx biddle il check it out and give tarty a ring do you have to buy the whole hub or can i get the body sepratly seen it on chain reaction cycles so aint surehttp://www.tartybikes.co.uk/product.php?pr...;category_id=22They do the body shell and some of the pawls and springs but they dont seem to do the part where you would put the cassete. Your best bet is to look into say a hope xc hub or mono hub on ebay or through the forum if your gonna run gears. If yourruning a single speed setup the hope pro to will be fine as the hub is made for single speed setups with a small size feehub.The other option you could do is get a DMR hub and get a feewheel to scew onto the rear a few other riders i know have done the same and seems to work fine.Biddle. Edited October 15, 2009 by David Biddle™ Quote Link to comment Share on other sites More sharing options...
scotty007 Posted October 15, 2009 Author Report Share Posted October 15, 2009 (edited) http://www.tartybikes.co.uk/product.php?pr...;category_id=22They do the body shell and some of the pawls and springs but they dont seem to do the part where you would put the cassete. Your best bet is to look into say a hope xc hub or mono hub on ebay or through the forum if your gonna run gears. If yourruning a single speed setup the hope pro to will be fine as the hub is made for single speed setups with a small size feehub.The other option you could do is get a DMR hub and get a feewheel to scew onto the rear a few other riders i know have done the same and seems to work fine.Biddle.i run a single speed set up on the rear think il give chain reaction a ring and see whts up with the freehub body iv seen on there if not how would i take the old freehub body of my halo any ideas . and another thing mate cant buy or sell on here cause im not validated yet how do you get validated on here biddle hers the link to the freehub body see wht you think http://www.chainreactioncycles.com/Models.aspx?ModelID=25986 Edited October 15, 2009 by scotty007 Quote Link to comment Share on other sites More sharing options...
David Biddle™ Posted October 15, 2009 Report Share Posted October 15, 2009 i run a single speed set up on the rear think il give chain reaction a ring and see whts up with the freehub body iv seen on there if not how would i take the old freehub body of my halo any ideas . and another thing mate cant buy or sell on here cause im not validated yet how do you get validated on here biddle hers the link to the freehub body see wht you think http://www.chainreactioncycles.com/Models.aspx?ModelID=25986The freehub seems ok you just need to check if your old one has the same rachet system as the hope cassete body.Best bet is to have ago at taking the cassete body off your wheel and have a look at what you have there.Ill happly help you out as much as i can if you need any hints ill be on msn if not ill be on here.Biddle. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted October 16, 2009 Report Share Posted October 16, 2009 If you're saying your Halo hub has broke you can't replace the freehub with a hope freehub, which is what it sounds like you're saying. You'll need a Halo freehub and that's if they even do spares for them.If you have a hope hub and the freehub has broke on it, you could possibly send it back to hope for repair.But I'm only guessing whether you have a Halo hub or a hope hub. Either way, whatever hub you have it will build up onto your Halo rim with the correct size spokes and hole drillings. Quote Link to comment Share on other sites More sharing options...
