V Brake To Hydrolic Rim Brakes... Help please
Coffee78
Hello all... Im new to trials and this forum for that matter' Sorry if iv posted this in the wrong place...
"Anyway" a little help would not go a miss please.. Iv just got an Onza hitman bike with the intention of putting a hydraulic rim brake on the rear wheel but to my dispare there only made for v brakes :( so i was wondering if there way a converter on the market or some other way i could fit hydraulic's too it... Thanx all.... Hope to hear some reply's soon :)
That i know of there is now way you can fit that magura on the back theres alot of pressure on that part of the brakes sometimes and fiting something on i feel just wouldnt have enough support.
Yes you can use magura evo adaptors and they are available from www.tartybikes.co.uk
Hope this helps
o ignore me then lol can you fit that on the rear brake though
Go for the rear hydraulic but I honestly think you should stick with the front vee.
I've just gone from front Magura to front vee and i'm loving the vee alot more.
Just get an Avid SD7 lever and some good pads like the Inspired Phats or the TNN's or the Plazzi's or something, lube the cable, set it up and it'll be great. ;)
Hi all... Thanx for the replys ill look in to all the suggestions' Just one thing though its the rear brake where i want more power.. im very happy with the front v brake its nice and powerful' one of the replys from rab shropshire said to use an evo adaptor' just a quick question about that' Does it fit ok for the rear brake??? Cheers :~)
I think you should put a quality vee on there, a hydro brake will be heavier, harder to set up and no more powerful. I would sell my teeth to have a frame with vee mounts!
Agreed, if I had clearence for v-brakes on the rear, i would run them. Vs are the way to go, just get some decent pads. On the other hand if you are set on using maguras you should know that they were originally designed for v-mounts using the evo adaptor. 4 bolt mounts came later (as did the mount system for their road version).
Oh right cheers for the info' I was thinkin new pads and iv heard about grinding the rim aswell. I just thourght hydro brakes were stronger thats all only reason i say that is cos my mountaion bike has hydro disk brakes... Cheers again for the info very helpfull :)
Do you ride in the wet? If not don't grind your rim, get some spanish fly v-pads and the power will be immense on a smooth rim. Alternatively you could get some heatsinks and grind your rim, either will work well.
Also what brake are you using at the moment (lever, arms, pads, booster)? If it is something sh*te then change it for some avid stuff and probably get a booster as well (though not strictly necessary).
its just the standard one's that came with the onza bike sstein. I was thinking TNN pads on a grind' is that not a good idea then??? I was also thinking of investin in some avid brakes to go with a ground rim...
Once again, it is all dependent on your setup. What sort of grind (harsh/medium/light) as different pads are for different grinds. I would say your best bet is to get some avid sd5 brake arms and lever and a decent set of v-pads meant for the sort of grind that you will be using. Once again; Heatsink pads seem quite popular for Vs, I would also look at rock v-pads for a medium grind.
