Over Coming My Fear
TROYston
I can get up 7 pallets to bash on my 03 onza t-mag/t-master fine, i can get up there fine, i just have a massive fear of dropping off stuff, even 3 pallet makes me cack myself.
I tried the drop off a curb back wheel then front jobbie, but i fall off the pedal.
What am i doing wrong?
Like most people say that getting up stuff is the hardest part, yet i find that that's the easiest :o.
Hmm, play about on your back wheel for a while, I mean like half a day or so. Explore every move you can think of using only your back wheel. Dont worry to much about going up and down stuff, just concentrate on your acuracy and confidence on the rear wheel. Practice small hops, big hops, spins, hopping back wards, hopping to the side, combos, turning on the spot. Then once you have completely exhausted your imagination, try hopping up and down a curb. Then film an epic video (Y)
just do it. instead of hesitating on drops just do it. if you can get into the habit of stacking then attempting the same thing with no hesitation it helps allot. scary but its a damn good buzz. eye up a bus stop and aim to drop off it. if you get the balls to do so all drops below that hight seem easy. sounds like a hardcore way of doing things but when you nail it its awesome and you progress quick. just grit your teeth and man up. concentrate hard and dont think of the what if, instead think of the after success. when you get the bus stop your laughing. my first bus stop scared the living shite out of me but now, well you will understand. the same theory of dropping of around 1 1/2 meters works for larger.
Or, just tilt your ankles a bit so your feet stay horizontal at all times, they way it's difficult for them to slip off, then build up from kerbs to bigger kerbs, then steps, then small walls, then ledges, etc :P practise is progress, and progress is striving for perfection :)
no it won't, you might get higher once you get a new bike but that will be because you've been riding for longer
Ahh skeen , now i get you :P,
Ohh what about pedals, it the moment im using felt pedals, and grip is nearly gone, will this help me drop off with out slipping of?
