Zebidee
TROYston
Here it is my Onza T-Mag or T-Master, had a lot of arguments about it.
The colour scheme is going to be eggshell blue and eggshell orange, with brown 50's koxx stickers the blue is done, just waiting on tart to get the orange Koxx 19" rim in then I can colour match the paint and continue.
Any thoughts, comments will be taken in, and ideas.
The aim for it is to get it looking like a Ford GT40 MK1.
From the Beau Memorial ride in Bristol this year, I just learnt to Front wheel tap, that was my first ever wall.
Im 99% sure its a t master as i had one for ages.
Depending on which year yours is, a koxx rim might be too wide, would double check first!
on the one in my shed it has a echo/old try-all rim on and its pretty damn wide and it's still got about 1cm gap either side when the slave's are all the way out.
Yer the rear brake is a bit poo because the rear is amazingly wide. and flexy, booster time (Y).
But will a booster fit ? :o
should do. but I dont no I never used it with a booster. I only ever had problems with my freewheel and bottom bracket as I had no money so I kept buying Shimano crap through ebay. Never again do I buy shimano for trials, snapped the bb, wrecked the pawls inside the freewheel so that it was basically a freecoaster freewheel as it only ever seemed to work when I did pedal hops. After 2 days of that it completely went.
It looks weird. Doesn't it weaken the wheel? Like if you hit inbetween where the clusters of spokes are then it could snap really easily, couldn't it? It must've taken ages to do, too..
Nope took about 5 mins to build and true, im fast at building them anyway normally and seeming its only 16 spokes its all gravy. i have dropped and threw it multiple times off my shed and its still true as.
Yer i have a VIZ. bb inside and the is rather somewhat smooth and strong, soon to be isis though. im going to buy a 2nd hand 4 bolt booster and find out. also my treads are knackered on the 4-bolt mount on the driveside so it shall be fun trying to fit it.
The t-mag and the t-master were exactly the same frame just painted differently, the t-comp had a big welded plate stuck on the top tube. But if it was a t-comp it'd probably be broken by now. :P
