Front Or Rear Freewheel?
BringThatShtIn
13 members have voted
  1. 1. Front freewheel or rear freehub?
    • FFW
      9
    • RFH
      4
A pro 2 is a freehub, freehub and freewheels are different things. Freehubs are more associated with stocks due to the frame spacing (135mm) compared to a mods (116mm) frame spacing, so there are a wider choice of free hub for stocks.
A free hub basically has the freewheel built into the hub, that's the easiest way to describe it.
FFW set ups are generally cheaper, as you can get a good freewheel for £40-£50, where as a pro 2 is £130, or if you can afford it a Chris king hub is £300.
FFW is standard on all good bikes because rear freewheels are sh*t, and most full builds you buy wont come with a rear freehub, unless you pay extra.
EDIT: Sorry if you already knew all that, just sounded like you were a bit confused between ffw and a freehub by your post :P
Edited by austen
Yeah I did know =) Thanks for the info though.
That's why I said FFW or RFH. I knew they were different. I was just wondering about it 'cause of all the trials pros who talk about 'the pro2 trials is the best hub' blah blah blah, but if all the good people have FFW and fixed hubs anyway, then how do they know?
