Dale-Hill Posted September 30, 2009 Report Share Posted September 30, 2009 Right as title says. I'm wondering what is the easiest was to make my Echo urban mod rim holes square.I'm not doing it to save weight really, I'm doing to for a change and I like the look off the Trialtech front ones.I vagily remember one of the tarty lot did it? (Only half of the rim though) Dale Quote Link to comment Share on other sites More sharing options...
Muel Posted September 30, 2009 Report Share Posted September 30, 2009 I know a guy who did it, takes forever! I just cut mine out to 25mm with a holesaw, took almost no time at all and looks sweeeeeeet, saved a lot of weight aswell. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 30, 2009 Report Share Posted September 30, 2009 Use a rotary file or desouter.Matt Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 30, 2009 Author Report Share Posted September 30, 2009 Both of them would jsut make the circle bigger, not square Unless i'm missing something? Quote Link to comment Share on other sites More sharing options...
Muel Posted September 30, 2009 Report Share Posted September 30, 2009 A dremel with a really little bit on it? like a 3mm bit?They'd be roughly square... Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 30, 2009 Report Share Posted September 30, 2009 (edited) You are indeed missing something.Get a small rotary file- if you can't get one pm me and I'll send you one. Put it in a pillar drill (small)Wap the speed up.Use like a manual sort of milling machine, you are the servo motors.So you must make the noises of the motors while you do it, tis law.This must be done with the wheel deconstructed.Just because I am blonde and have lush tits doesn't mean I am dumb.Matt Edited September 30, 2009 by Matt Vandart Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 30, 2009 Author Report Share Posted September 30, 2009 You sir just made my day reading that last bit Quote Link to comment Share on other sites More sharing options...
Jamie East Posted September 30, 2009 Report Share Posted September 30, 2009 I used a file on my rim, wouldn't reccommend it unless you've got nothing better to do. Took me about 2 weeks to finish my rim. Using some sort of power tool/drill/dremel must be quicker and easier. This is what it turned out like, didn't really save much weight, but looks pimp Jamie Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 30, 2009 Author Report Share Posted September 30, 2009 I used a file on my rim, wouldn't reccommend it unless you've got nothing better to do. Took me about 2 weeks to finish my rim. Using some sort of power tool/drill/dremel must be quicker and easier. This is what it turned out like, didn't really save much weight, but looks pimp *pic*JamieYeah I used a file on my V!Z front one. I could do the rear on like that. But was just wondering if there was a quicker/esier way And yeah like I said not really bothered about the weight, I just think it looks pimp. Quote Link to comment Share on other sites More sharing options...
eep803 Posted October 4, 2009 Report Share Posted October 4, 2009 You can get hole cutters which are used for cutting rectangular holes in metal panels for mounting switches in. They consist of two parts, a square/rectangular hole in a block and asharp edged square/rectangular punch. They are on a threaded rod and when screwed together from either side of the metal will punch out a shape. www.rswww.com do them. Quote Link to comment Share on other sites More sharing options...
sayshell Posted October 4, 2009 Report Share Posted October 4, 2009 isnt the echo sl the same thing as an urban but with square holes? Why not buy that? It might look ugly if you make them into squares if you have a coloured rim because then you will have silver streaks between the rim tape and rim. Its a cool idea though! Quote Link to comment Share on other sites More sharing options...
