Ready Bled Maguras
bikeperson45
i got my Magura HS-33 from Tartybikes today and after fitting it I found that for the wheel to lock i had to pull the lever in contact with the bars. i was wondering if this had ever happened with anyone before, because on their website it says they come fled with Magura Royal Blood so i was expecting them to work well. I didn't want to have to bleed it as soon as i got it, and really thought that i could could just put it on and go.
Thanks
Edited by bikeperson45
If you bought them new from tartybikes I'd give them a call, they may send you out a replacement.
Does the lever keep moving after the pads have hit the rim?
Does the lever keep moving after the pads have hit the rim? When you said you set them up as close as you can, do you mean the pads are right up against the rim, or do you mean as close as you can as in the maguras can't go any closer because of something else?
Do you have any slack in the leaver, like when you pull the lever the pistons don't move?
Edited by JT!
Tarty won't have bled it either, it will have been magura bled, so it's not their fault anyway.
My mistake, wasn't trying to sound like I was blaming them.
When I pull the lever and the pads have hit the rim I can keep pulling the lever. The pads hit the rim with the lever about half way down, but then i can pull it to the handle bars.
i can't have the pads completely 2mm away from the rim because it's a bit buckled, I'd say about 3 to 5mm away from the rim.
Thanks for all the help
Try setting up the pads real close, they should be between 1mm and 1.5mm. See if that works. You may find that they're too far away and by time the pads hit the rim your lever is pretty much all the way there.
