Diskbrakes
Sangsta.
I come from downhill so I'm used to massive disk brakes and I trust in my brakes to stop and lock under any conditions. The only problem I ever have is bent disk rotors, how often do you guys bend rotors? After trying a friends HS33s i cant say i could trust them to lock and hold my weight, I'm sure it's just his set, but is it worth getting disks?
I strongly recomend that you stay AWAY from Avid Juicy 3's and Hayes Strocker Rydes. Ive gone through 3 Juicy's and 2 Strocker's.
But my Avid BB5's are sweet as.Thay are cheaper than BB7's and the only difference is BB7's have 2 adjusters instead of one.
I have a pair of BB5's on my bike as well and they work just fine, with one exception.
I read up on BB5's and found that some people have had problems with the front locking up on it's own, and i can verify that from own experience. Has happened twice so far, both times after getting back on after a full stop using my front brakes so no accidents so far but it has left me a bit cautious when it comes to pulling the front brake to hard.
What about juicy 7's? I have one on the front and it's amazing =)
Hi mate. personally. The avid bb7. Im using 185 front rotor with try-all forks. (with the reinforced steerer) not sure how strong the crown will be on your forks so go for the 165. Its an amazing brake, doddle to set up/maintain and as cheap as a wank. Not tried the new Try-all/hope but i didnt get on with old hope mono. And the formula oro that Tarty sold is abit weak.
