txt2007 Posted September 23, 2009 Report Share Posted September 23, 2009 When i put the game in it comes up with "16 bit MS-DOS subsystem This system does not support fullscreen mode. Choose 'close' to terminate the application" i'm running windows vista, are there any settings i need to change before i can play it?The games from 1990 if that helps...Thanks. Quote Link to comment Share on other sites More sharing options...
JD™ Posted September 23, 2009 Report Share Posted September 23, 2009 When i put the game in it comes up with "16 bit MS-DOS subsystem This system does not support fullscreen mode. Choose 'close' to terminate the application" i'm running windows vista, are there any settings i need to change before i can play it?The games from 1990 if that helps...Thanks.I'm not on a Vista machine at the moment, but somewhere in the properties menu (right click on game -> properties) there is a 'compatability' option, where you can choose to run it in windows 95/98 mode. I dunno whether that'll work with a game so old though. Quote Link to comment Share on other sites More sharing options...
anzo Posted September 23, 2009 Report Share Posted September 23, 2009 You will not be able to run this game from windows Vista, as the message suggests it wont support full screen 16bit.You can however download DosBox and run it from a window within Vista Let me know if you have any problems. Quote Link to comment Share on other sites More sharing options...
