What Should I Do
thinkdougie
I currently have a Echo Team 07, which rides fine and I have not problems with it
But I have been offered my bike + £200 for this top spec czar in excellent condition
Frame: Czar Long 07 £249.99
Forks: Echo lites (black) £69.99
Stem: Trialtech sport forged (black) £34.99
Handlebars: Trialtech risers (white) £49.99
Headset: Echo 6061(red) £44.99 with Hope headset stackers (£7)
Bottom Bracket: Try-all Isis 128mm £50.00
Cranks: Echo 6061 Isis cranks 160mm £50.99
Pedals: Dmr V12’s (black) £49.99
Freewheel: Tensile 18 tooth £34.99
Front brake: Avid bb7 180(£44.99)and sd7 lever(£12)
Rear Brake: Magura 05+(£64.99) lever with zoo red lever blade (£9.99),Red magura hosing (£8), Plaz crm pads (£18)
Brake booster: Zhi 2-bolt silver booster £23.00
Brake mounts: Echo cnc red mounts £23.99
Rear hub: Viz Fixed hub(red) £44.99
Rear rim: Try-all Black 32 hole rim £39.99
Spokes& nipples: Muting spokes £9.99& Halo red nipples £8.99
Tyres: Maxxis creepy crawlers F&R £35 the pair
Front hub: Onza Sealed front disk hub £29.99
Front rim: Onza hog drilled rim £24.99
Grips: Monty foam £4.00
Front QR: Hope QR skewer £14.99
Rear sprocket: Trialtech sprocket £12.99
http://s279.photobucket.com/albums/kk156/R...nt=SDC13934.jpg
http://s279.photobucket.com/albums/kk156/R...nt=SDC13935.jpg
Let me know what you think
Edited by thinkdougie
Echo Team 07
Frame: Echo Team 07
Stem: Monty
Handlebars: Monty
Headset:Monty Top Cap
Pedals: Gusset Slim Jim Alloy
Rear hub: Echo Black
Front hub: Viz gold hub
Front rim: No idea
Grips: Echo
I would swap but just check it for cracks and stuff, you can never know what could happen. Maybe offer like £150 and your bike and see if he/she will take it, if not then offer full amount an get swapped after checking the bike (if possible). Hope this post has helped. Jordan x
Edited by JLKitching
