Patrick_ Posted September 20, 2009 Report Share Posted September 20, 2009 buying my bike in a few weeks and ive just been browsing the forums for tips e.t.c and i came across grind and smooth brakes, a tad confused, anyone want to poit out the difference Quote Link to comment Share on other sites More sharing options...
George.E Posted September 20, 2009 Report Share Posted September 20, 2009 GrindIs when you grind the side of the rim to make a ruff surface to gain better hold and bite for your brake pads.The braking is alot sharper and stronger so most riders prefur to do this.( they also don't slip in the wet unlike smooth rims)SmoothIs when you just have a smooth rim, like on a normal bike wheel.Different pads work on ground and smooth rims.Hope this can come to some help.George. Quote Link to comment Share on other sites More sharing options...
Patrick_ Posted September 20, 2009 Author Report Share Posted September 20, 2009 GrindIs when you grind the side of the rim to make a ruff surface to gain better hold and bite for your brake pads.The braking is alot sharper and stronger so most riders prefur to do this.( they also don't slip in the wet unlike smooth rims)SmoothIs when you just have a smooth rim, like on a normal bike wheel.Different pads work on ground and smooth rims.Hope this can come to some help.George.cheers, can you grind the rim with like a dremel, or would you have to get a angle grinder Quote Link to comment Share on other sites More sharing options...
George.E Posted September 20, 2009 Report Share Posted September 20, 2009 cheers, can you grind the rim with like a dremel, or would you have to get a angle grinderAn angle grinder is how i do it, I wouldn't think a dremel would work to be honest.Are you planning on grinding your rims then ?If so what pads are you running ? Quote Link to comment Share on other sites More sharing options...
Patrick_ Posted September 20, 2009 Author Report Share Posted September 20, 2009 An angle grinder is how i do it, I wouldn't think a dremel would work to be honest.Are you planning on grinding your rims then ?If so what pads are you running ?i havent got my bike yet, just came across a topic discussing pads just wondered what they were on about Quote Link to comment Share on other sites More sharing options...
