Jamie_Trials Posted September 19, 2009 Report Share Posted September 19, 2009 (edited) Hi,there's a few things i don't really know about since getting a stock.There's a little problem with my hope pro 2 hub, every time i tighten up the drive side bolt, the cog stops moving so i cant ride the bike unless i dont have it tight, anybody know the problem? thanks.Is there any stock 2.5 rear tyres that are cheap around 25 maxAnd does anybody know that bit which you attach the chain tensioner to which will fit a 07 GUAny help appreciated EDIT: my bearings in the hub shell are dead (ones on the axle) is it 61903 that i need to replace them? and is there any on tarty like the echo ones that will fit anyway? Edited September 20, 2009 by Jamie_Trials Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted September 19, 2009 Report Share Posted September 19, 2009 There's a little problem with my hope pro 2 hub, every time i tighten up the drive side bolt, the cog stops moving so i cant ride the bike unless i dont have it tight, anybody know the problem? thanks.could there be a spacer missing - ive got a pro 2 and never had a problemIs there any stock 2.5 rear tyres that are cheap around 25 maxim sure theres a maxxis tyre under that price or a specialized chunder - worst option look on ebay Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 19, 2009 Report Share Posted September 19, 2009 k type mech hangerno idea about your hope.and maxxis minion dual ply supertacky Quote Link to comment Share on other sites More sharing options...
Muel Posted September 19, 2009 Report Share Posted September 19, 2009 My hope does the same thing, I just tightened it and rode it until it sorted itself out. (Only happens if i rebuild mine though). Check the spacer is in though, that's the first thing to check. Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 19, 2009 Author Report Share Posted September 19, 2009 Thanks alot guys and it was a missing spacer after all Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted September 19, 2009 Report Share Posted September 19, 2009 Thanks alot guys and it was a missing spacer after all thought it would have been something simple like thatglad you got it sorted Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 19, 2009 Report Share Posted September 19, 2009 Hi,there's a few things i don't really know about since getting a stock.There's a little problem with my hope pro 2 hub, every time i tighten up the drive side bolt, the cog stops moving so i cant ride the bike unless i dont have it tight, anybody know the problem? thanks. - spacerIs there any stock 2.5 rear tyres that are cheap around 25 max - pm me for link And does anybody know that bit which you attach the chain tensioner to which will fit a 07 GU - 'k' type mech hanger, check tartybikesAny help appreciated Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted September 20, 2009 Author Report Share Posted September 20, 2009 Bit more help on something else now :/(at the top) Quote Link to comment Share on other sites More sharing options...
