jambo Posted September 17, 2009 Report Share Posted September 17, 2009 pretty simple where can i get a 22mm seat post for a Curtis T1?HELP PLEASE! Quote Link to comment Share on other sites More sharing options...
matt_urban Posted September 17, 2009 Report Share Posted September 17, 2009 not sure if you can get a normal post i think it was made to take a mini seat /post i have one new at work i will messure it for youor if you wanna run a pivitol i might be able to get you one and turn it down from 25.4 to 22 for cost of post plus postage and 10er Quote Link to comment Share on other sites More sharing options...
jambo Posted September 17, 2009 Author Report Share Posted September 17, 2009 oh that would be f**king ace how thick is the wall of the post? Quote Link to comment Share on other sites More sharing options...
Skoze Posted September 17, 2009 Report Share Posted September 17, 2009 Not very thick at all, i had to machine mine down a bit to fit in my seat-tube. Only took a tiny bit off, seems pretty thin now though. Wouldn't want to take the amount you need off to get it down to 22mm though, could see there being a distinct lack of metal by the end of it! Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 17, 2009 Report Share Posted September 17, 2009 You could... cut the pivotal part off, machine it down to fit, and weld it to a 22mm piece of decent tube of the same metal. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted September 18, 2009 Report Share Posted September 18, 2009 little kids bikes use that size i think. Turning down prob wont happen as most of those bmx posts are thin to be light as f**k. Personally id get some 22mm tube and try and 'machine' a pivotal interface with a grinder on a bit of plate, then get it welded to the tube-sorted. Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 18, 2009 Report Share Posted September 18, 2009 It's 1.6mm off effectively, which might be alright. The only problem is is that the inside of a typical BMX pivotal (And probably the over-sized MTB ones too?) is ovalised, so at the front and rear it should be plenty thick enough, but the sides might not be. The only other option is to just use a typical kids bike seatpost - the old school ones with a seperate bolt-up clamp. You could probably bodge a Pivotal head onto one of those posts if you've got a welding enabled friend? It's all a bit sketchy though... Quote Link to comment Share on other sites More sharing options...
jambo Posted September 19, 2009 Author Report Share Posted September 19, 2009 sounds good boys, my mate has got me a bit of 22 mm tube and getting it welded onto a steel seat clamp.cheers Ross. Quote Link to comment Share on other sites More sharing options...
