adrenilinjunky Posted September 16, 2009 Report Share Posted September 16, 2009 I have recently suffered a buckle in the back wheel and got a warped tyre as a result. Does anyone know how to fix this? Quote Link to comment Share on other sites More sharing options...
Muel Posted September 16, 2009 Report Share Posted September 16, 2009 A warped tyre? Just put it on and pump it up lol. Quote Link to comment Share on other sites More sharing options...
trailsedward Posted September 16, 2009 Report Share Posted September 16, 2009 lol Quote Link to comment Share on other sites More sharing options...
forteh Posted September 16, 2009 Report Share Posted September 16, 2009 My rubber queen has a kink in it, looks like my back wheel is buckled but its not. I think it was caused by bigman hanging it from a hook in his garage for ages before I bought it off him, because the casing is so lightweight its permanently deformed it Try taking the tyre off, refitting it and pumping it up really hard, it might get the lump out Quote Link to comment Share on other sites More sharing options...
adrenilinjunky Posted September 16, 2009 Author Report Share Posted September 16, 2009 A warped tyre? Just put it on and pump it up lol.did that it still got big kink in it My rubber queen has a kink in it, looks like my back wheel is buckled but its not. I think it was caused by bigman hanging it from a hook in his garage for ages before I bought it off him, because the casing is so lightweight its permanently deformed it Try taking the tyre off, refitting it and pumping it up really hard, it might get the lump out yea it jus came off the rim when i did that "/ Quote Link to comment Share on other sites More sharing options...
Guest itstroy08 Posted September 17, 2009 Report Share Posted September 17, 2009 what crappy rim allows the tyre to pop off under heavy pressures? Quote Link to comment Share on other sites More sharing options...
adrenilinjunky Posted September 17, 2009 Author Report Share Posted September 17, 2009 what crappy rim allows the tyre to pop off under heavy pressures?it pops off coss the tyre is warped n has a bulge wen i pump it up then cos there a bulge the beeding pops out the rim, not the rim thats crap the tyre just ruined... "/ Quote Link to comment Share on other sites More sharing options...
forteh Posted September 17, 2009 Report Share Posted September 17, 2009 Whilst youre pumping it up, stop every so often and make sure the warped bit it seated into the bead properly, then continue pumping; its possible you have a loose tyre/rim and it just doesnt naturally seat. If the rim is dinged then that will stop the bead from seating properly, just need to take a bit of time and effort when pumping it up Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted September 17, 2009 Report Share Posted September 17, 2009 You've probably got a flat spot in your wheel. Meaning the bead of the tyre doesn't sit right where it should in the rim, causing it to pop off. Quote Link to comment Share on other sites More sharing options...
adrenilinjunky Posted September 18, 2009 Author Report Share Posted September 18, 2009 Whilst youre pumping it up, stop every so often and make sure the warped bit it seated into the bead properly, then continue pumping; its possible you have a loose tyre/rim and it just doesnt naturally seat. If the rim is dinged then that will stop the bead from seating properly, just need to take a bit of time and effort when pumping it up yea but i'm lazy Lol i'll give it a go cheers Quote Link to comment Share on other sites More sharing options...
martin555 Posted September 18, 2009 Report Share Posted September 18, 2009 yea but i'm lazyWell get a new tyre then. Quote Link to comment Share on other sites More sharing options...
adrenilinjunky Posted September 18, 2009 Author Report Share Posted September 18, 2009 Well get a new tyre then.Lol yea i would but i am skint "/ Quote Link to comment Share on other sites More sharing options...
