Magura Brake Dosent Fit
marcus heath
hi i ve got a problem ,ive just got a new onza ice frame i fitted everthing but ive got a hs33 magura from the magura web page and the pads are to far away from the rim and there touching the tyre do i need a new hs33 brake,does anyone why its like that ?
thanks. Marcus
So are the pads above the rim on the tyre?
by the sounds of things you just have them set up wrong, try undoing the clamp a little and angling the cylinder so it hits the rim when pulled. if the pads not touching the rim try moving the cylinder forwad in the clamp a bit as well or unwind your tpa.
ive tried every thing, moving all the cilinders ...
but it just doesnt seem to work i think ive got the wrong brake
i had a monty 219
Oh ok, I was thinking you might have had a t-vee, some cheaper bikes have 20" rear wheels instead of 19".
Where abouts does your back wheels sit in the dropouts? Could you possibly take a link out of your chain? That would allow the wheel to sit further into the dropouts and the wheel will be more towards the bike.
thanks. Marcus
Sounds as if you need to take a link out of your chain!!!! But pictures would help.
Tom
heres some pics
on theese pics the chain is realy slack and when i pulled the brake lever it was realy soft it pulled up to the grips
wat do u think about the pictures ??
heres some pics
They are V mounts not 4 bolt mounts that won't help you need to get some 4 bolt mounts!!!
The mounts you require look like this!!
