rob.c Posted September 13, 2009 Report Share Posted September 13, 2009 I have got the t-master hub but will not fit i dont no y the bolts screw in all the way and the hub is still lose it is a onza t-pro frame eny help Quote Link to comment Share on other sites More sharing options...
Muel Posted September 13, 2009 Report Share Posted September 13, 2009 You got snail cams in there? Pretty sure they're designed for them. Quote Link to comment Share on other sites More sharing options...
rob.c Posted September 13, 2009 Author Report Share Posted September 13, 2009 will Chain tugs do the same job i have not got eny snail cams Quote Link to comment Share on other sites More sharing options...
trials-ryan Posted September 13, 2009 Report Share Posted September 13, 2009 You got snail cams in there? Pretty sure they're designed for them.Most onza hubs are designed for chain tugs and it might be that your cones are lose. Quote Link to comment Share on other sites More sharing options...
rob.c Posted September 14, 2009 Author Report Share Posted September 14, 2009 it is a fixed hub Quote Link to comment Share on other sites More sharing options...
Muel Posted September 14, 2009 Report Share Posted September 14, 2009 Loose cones would make this problem better, not worse, as the bolts wouldn't be tightening down onto the ends of the axle as quickly.Just stick the tugs in dude, should sort it. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 15, 2009 Report Share Posted September 15, 2009 Just stick the tugs in dude, should sort it.Incidentally, were you planning on running the hub with any tensioning devices? Quote Link to comment Share on other sites More sharing options...
Daniel C Posted September 15, 2009 Report Share Posted September 15, 2009 Put the tensioners on the inside of the frame instead of the outside.The hub is designed to use snail cams. Quote Link to comment Share on other sites More sharing options...
trials-ryan Posted September 15, 2009 Report Share Posted September 15, 2009 Put the tensioners on the inside of the frame instead of the outside.The hub is designed to use snail cams. Onza hubs are designed for chain tugs. Quote Link to comment Share on other sites More sharing options...
rob.c Posted September 16, 2009 Author Report Share Posted September 16, 2009 thanks for the help it now fits thanks rob Quote Link to comment Share on other sites More sharing options...
