Mikey-uk Posted September 10, 2009 Report Share Posted September 10, 2009 Heya, been browsing this forum for a while but only now decided to make an account (nothing to contribute as i dont know enough about trials)Basically, bought the Mod bike from pogonation and the front lever blade snapped, i would replace it straight away but i don't know anything about hydralic disk levers or what blade to use.Can i use any old hydrolic disk blade? I'm wondering because i don't want to use the wrong part and mess it up xDThanks in advance. Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 10, 2009 Report Share Posted September 10, 2009 Heya, been browsing this forum for a while but only now decided to make an account (nothing to contribute as i dont know enough about trials)Basically, bought the Mod bike from pogonation and the front lever blade snapped, i would replace it straight away but i don't know anything about hydralic disk levers or what blade to use.Can i use any old hydrolic disk blade? I'm wondering because i don't want to use the wrong part and mess it up xDThanks in advance.no you need the original you cant just chuck anyold one on Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 10, 2009 Author Report Share Posted September 10, 2009 no you need the original you cant just chuck anyold one onDo you know where i can buy a Marta lever blade then? All i can find are the complete carbon levers, all i want is the blade. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 10, 2009 Author Report Share Posted September 10, 2009 (edited) It's either missing or i'm being really slow but i couldn't see an edit button.Marta Lever Blade <-- Will these do for the front Marta disk? I wanted a 2finger blade but if thats all that i can get and if it is indeed ONLY marta blades that work then they will have to do....Ok i can edit this post, anyway, found out its £72 for the 2finger Marta lever from that site, is there any way to replace the BLADE only for a cheaper price? Edited September 10, 2009 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted September 11, 2009 Report Share Posted September 11, 2009 ring magura direct if the blade has just snapped then its a fault with the lever and they should replace it for youhowever if it has been abused you may need you pay for one btw ... have you checked ebay? i had a quick look but keep checking the only other thing to do is to get another disk brakeplenty in the for sale section Quote Link to comment Share on other sites More sharing options...
only1monty Posted September 11, 2009 Report Share Posted September 11, 2009 i havent had a look but maybe try chain reaction cycles as they usually have loads of parts but unfortunately tartybikes dont sell the marta levers... Quote Link to comment Share on other sites More sharing options...
sstein Posted September 11, 2009 Report Share Posted September 11, 2009 Get a third party one as magura spares are quite hard to get as they need to come from germany. I think straitline might do something that will fit however they are quite pricey. Alternatively you could just ring magura yourself or get your lbs to order one in! Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 12, 2009 Author Report Share Posted September 12, 2009 Thanks for the replys guys, the reason im asking about blades is because the marta blade is too expensive, i'll give magura a ring though and find out about getting them to repair it. Getting a new disk is out of the question as its only the blade in the lever thats gone. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 13, 2009 Author Report Share Posted September 13, 2009 Need more input please, maybe i could weald it back together? The blade isnt wreaked, just snapped.As a tempory fix. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 14, 2009 Author Report Share Posted September 14, 2009 Still awaiting more input... Quote Link to comment Share on other sites More sharing options...
sstein Posted September 14, 2009 Report Share Posted September 14, 2009 Don't weld it, get a new one, or live with it! Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 14, 2009 Author Report Share Posted September 14, 2009 Trying to order a new one, this is a balls ache -.-Need a new bb - might aswell upgrade to ISIS - means new cranks.new marta blade - £40 w/o installationNeeds HS33 rear lever fitting -.-Gahhh, this is after new forks, headset, cross over on rear HS33... Sold suposidly in 'working order' Quote Link to comment Share on other sites More sharing options...
sstein Posted September 15, 2009 Report Share Posted September 15, 2009 Trying to order a new one, this is a balls ache -.-Need a new bb - might aswell upgrade to ISIS - means new cranks.new marta blade - £40 w/o installationNeeds HS33 rear lever fitting -.-Gahhh, this is after new forks, headset, cross over on rear HS33... Sold suposidly in 'working order'there is no reason to go to isis if you have a decent set of cranks, just make sure you keep it tight!don't get the blade fitted, do it yourself, it is piss easy! Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted September 15, 2009 Author Report Share Posted September 15, 2009 there is no reason to go to isis if you have a decent set of cranks, just make sure you keep it tight!don't get the blade fitted, do it yourself, it is piss easy!Ok, sticking with Square taper then, saved myself about £40.I'm fairly new to trials and have never had any experiance with hydrolic brakes, i dont trust myself to fit a HS33 blade or a Marta blade.Anyone else from berkshire (prefer bracknell / crowthorne / sandhurst / camberly / wokingham as its all fairly close to me) that is confident enough to fit them for me? And give a garuntee if they f**k up they will replace the levers? And go for a ride after ofc Quote Link to comment Share on other sites More sharing options...
