Cotty08 Posted September 9, 2009 Report Share Posted September 9, 2009 Hey guys i put some tar on my rim last night (smooth) just spinning my wheel round and holding the tar to it and i found that my brake was just biting but not holding any one got other suggestions Quote Link to comment Share on other sites More sharing options...
Skoze Posted September 9, 2009 Report Share Posted September 9, 2009 Get yourself an angle grinder! With tar it's always a case of less is more, how much have you put on? Quote Link to comment Share on other sites More sharing options...
315r Posted September 9, 2009 Report Share Posted September 9, 2009 be aware of not to put a lot of tar in your rims.You have to put just a little line of tar in your rims, not a big band... Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 9, 2009 Report Share Posted September 9, 2009 6 years ago, when tar was cool, I used to draw loads of vertical lines (perpendicular to the rim edge) then drag the brake a bit to smush the tar over the rim surface and voila, nice even application.But now I have a grinder, so im cool again seriously though, tar can be dangerous so you should never apply too much, else youll find yourself going over the edge of a drop and your brake not letting go. This is not fun. Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted September 9, 2009 Report Share Posted September 9, 2009 Tar is good as long as you don't use too much.If you do use too much clean your rim with white spirit to get it off. Quote Link to comment Share on other sites More sharing options...
Mike Winton. Posted September 9, 2009 Report Share Posted September 9, 2009 Grinds are certainly NOT COOL.My smooth rim has never stuck with tar but plenty of my ground rims have slipped ending up with me in pain. Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 10, 2009 Report Share Posted September 10, 2009 i use to use tar until i was on a corner of a wall doin a gap and i launched my self and the pad stuk to the rim and nearly broke my faceGrinds are certainly COOL.My smooth rim has always stuck with tar but plenty of my ground rims have not slipped. Quote Link to comment Share on other sites More sharing options...
cam217 Posted September 11, 2009 Report Share Posted September 11, 2009 (edited) LOL i use tar, back in the day i used to colour my rim in before i found my self droping ten pallets for the first time and the pads not letting go of the rim, this resulted in me landing 2 wheel from ten pallets OUCH.i find a nice smooth rim some heatsink snowies or some soft pad and little tar, as has been said less is more when it comes to tar Edited September 11, 2009 by cam217 Quote Link to comment Share on other sites More sharing options...
