My Magura Louise Lacks Hold... Any Solutions?
RossMcd
Hey..
My magura Louise has lacked hold for a long time now.. And I have tried so many times to sort it and get it working with the same outcome every time. It never has held well since i got the bike really.. The only time it actually holds is when its pouring with rain.. Where then the back brake doesnt work so Im kinda in a Lose lose situation.. At one point I used to pour water on it before every ride but it would lose its hold gradually throughout the day. I have tried sanding the pads and rotor down and that hasnt worked either.
Has anyone got any suggestions that may get my brake working to a good standard?
Any sort of help is appreciated :) Thanks!
not sure if this works but a friend of mine has told me it dose mite be worth a try put the pads and the rota in white sprit leave it for 5mins then burn it off but be carful fire is not fun :(
NO, no no no no no no! white spirit is not good for brakes! if you want to try something, take the pads out, get some pliers, and cook them over a gas flame will they glow/smoke then dip them in clean water, the water will go dirty from all the shit on the pads, get new clean water, repeat till water remains clean after you dunk the pads. enjoy the steam and stuff. :)
Maybe you need to replace either of them, are they in good condition? Dont sand the rotor, just the pads. Also: sand pads, clean with some cloth soaked with some water, and burn them (pads). Or do what post above says, sounds prety good.
Edited by 3dd
