LiamWood! Posted September 8, 2009 Report Share Posted September 8, 2009 I bought a new roter, its had more than long enough to bed in but still no hold or bite!Ive scrubbed the roter in hot soapy water and sanded the pads down lighty, rode around with the brake on and poured water over the roter but to no effect?Anything else i can do? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 8, 2009 Report Share Posted September 8, 2009 I bought a new roter, its had more than long enough to bed in but still no hold or bite!Ive scrubbed the roter in hot soapy water and sanded the pads down lighty, rode around with the brake on and poured water over the roter but to no effect?Anything else i can do?New padsorrr.... try gritty mud on the pads/rotor Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted September 8, 2009 Report Share Posted September 8, 2009 air in the brake always tries to shift the blame to the pads/disc mo Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted September 8, 2009 Author Report Share Posted September 8, 2009 air in the brake always tries to shift the blame to the pads/disc mo Needs a good bleed then? When i bleed it should i use a syringe and push fluid up or just pump fluid down with the lever? Quote Link to comment Share on other sites More sharing options...
lewisrzoo Posted September 8, 2009 Report Share Posted September 8, 2009 Needs a good bleed then? When i bleed it should i use a syringe and push fluid up or just pump fluid down with the lever? Put it in the lever but make sure you make it straight first and pull the lever open the bleed nipple fill, it up a couple of times pull the lever in and out till theres no air tighten the bleed nipple up and you and the top cap thing and youre done. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted September 8, 2009 Report Share Posted September 8, 2009 to be honest i'd push the fluid up from the bottom using a syringe - tends to chase the air up through the system in my experience.can be messy though, you have been warned! Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted September 9, 2009 Author Report Share Posted September 9, 2009 Ok i will give it a go when i find my dot 4. Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted September 9, 2009 Report Share Posted September 9, 2009 I blead it from caliper to lever. I would try it the other way first. Mine still has air in! Quote Link to comment Share on other sites More sharing options...
