nyoli Posted September 7, 2009 Report Share Posted September 7, 2009 heylooking for forks, i've seen that all them have 2 paramaters for measure the geometry, for example:- Axle to Crown length: 400mm- Axle Offset: 35mmI've been doing theories about what they mean, but i think that the first parameter means the full lenght of the fork (from the stem to the hub) and the second means the distance that the fork goes forward.Yes, I know, my english is bad, but i try to explain myself as best as I know Thank you all Quote Link to comment Share on other sites More sharing options...
Bigman Posted September 7, 2009 Report Share Posted September 7, 2009 The fork length is the length of the fork from the axle to the crown of the fork, and the rake is the distance that the axle is positioned forwards from the vertical line of the steerer tube.Hope that helpsAdam Quote Link to comment Share on other sites More sharing options...
nyoli Posted September 7, 2009 Author Report Share Posted September 7, 2009 The fork length is the length of the fork from the axle to the crown of the fork, and the rake is the distance that the axle is positioned forwards from the vertical line of the steerer tube.Hope that helpsAdamthis is what i tried to explain, but i couldn't hahathanky you a lot bigman Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 7, 2009 Report Share Posted September 7, 2009 Yes, I know, my english is bad, but i try to explain myself as best as I know Your english is fine! Quote Link to comment Share on other sites More sharing options...
