I Am Confused And Need Help
Guest itstroy08
Guest itstroy08
Rite, now i am progessing in trials i have noticed that ive hit a brick wall because:
when i kick i have my right foot foward, where as hopping on the rear wheel i have my left foor foward
so my balence is messed up completely if i try hops right footed, and i cant kick and it dont feel nice with my left foot foward
When im coasting either foot is foward it dont bother me
because of this im stuck, and have no idea what to do, any help please would be much appreciated.
Thanks
Troy.
Edited by itstroy08
Guest itstroy08
I pedal kick straigt from both wheels, like i only do rolling kicks. static is just the same, i cant kick then hop on the rear, this is why i need advice you see.
If i try hopping on the right foor foward, i can only hop twice then my feet lift from the pedals and therefore i stop :P
Oh also i have canadian brake set-up (backwards) this is becuse of personal choice, the opposite way doesnt feel as good, if that helps ???
Edited by itstroy08
Guest itstroy08
well if you are better with your right hand use your right foot if its the left use your left that how i got out of that problem (Y)
im equally as shit with both hands :L
That's gonna be well annoying - you'll never be able to ride anyone else's bike. Swap the brakes back over and just practise - it won't take long to get used to it.
Guest itstroy08
its not actully, i have always liked it like this. and i fliiped the brakes over the over night, and cudnt do one thing, so im not changing the set-up.
Thanks
Troy.
Dont worry, i was in exactly the same posishion, for single kicks (both wheels on ground kick and rear hop you have to do a full 180 on pedals if you get me) then for multipul (on rear wheel let off brake pedal with left foot tiny bit, and bring it back up and hop then put rear brake back on, i am still learning this one how ever i can still do 5) all i can say is follow my advise and you will do it in time, just keep practicing is all i can say!
A legend called jack at essex trials and jump center taught me how to propally it isnt easy at all i know, but just keep going for it!
Good luck.
Laurence.
PS. add me on msn (glasheon@hotmail.co.uk) if you want any ferther help.
Edited by Laurence--Trials
I think your a nutter, you have clown brakes and clown feet.
At the end of the day your going to have to practise hopping with your right foot forward as thats the one thats got the power
Bollox
Also Bollox, I have always ridden this way and can ride my mates bikes just as well
Matt
1. If you were to step up onto something (just walking, not on a bike) like something high-ish like a table in one step, which leg would you feel more comfortable stepping up with first?
2. If you were to start a 100m sprint, and you started on the floor, which foot would out have forward?
3. Say you wanted do a 180 endo, which way do you spin?
Guest itstroy08
Good luck.
Laurence.
ahh lol, ill chat to you on msn mate
I'm a bit tard footed aswell.
Left foot for balancing, manuals, bunny hops up etc
Right foot for anything on the back wheel
Ahhhhh
so if yyour hopping on the rear how do you balance?
awnsers:
1-either foot, i just tried lol :S
2-i have no idea, i never have taken notice to this, id also say either, just testing
3-left, foot jams i jam my foot with the right foot and kick the bike right.
any ideas?
awnsers:
any ideas?
You're in a really shitty situation, my advice would be to learn everything as if you were a left foot forward rider. You rotate your bike clockwise when you ride, I assume when you do anything like 180's 360's foot jams, it'll always be clockwise so that tells me that you should be left foot forward, combine that with the fact that you backhop with your left foot forward means that you're doing everything right apart from when you pedal kick.
I guy I used to ride with had a similar problem, although i can barely remember what exactly it was, I did once hear him say something a long the lines that he had to do a quick pedal backwards to switch his forward foot.
Lean to pedal kick with the other foot, it's going to be a right bitch, and feel crap at first. But it has to be done.
(Y)
All you can really do is ride how you want. I always get told that I sidehop and spin the wrong way to my foot (right). I prefer to sidehop to my right not to my left like I keep getting told and I spin the back end to the right and if I spin straight on the rear wheel I spin also to the right. But I balance with the left foot forward.
So just keep practising, you will get used to doing the stuff you want with the foot you desire.
