lewiswolsey2009 Posted September 5, 2009 Report Share Posted September 5, 2009 Having a bit of a problem with my rear wheel. I tension my chain and tighten my wheel but for some reason after about 10 minutes of riding it will slip and rub against the frame.Does anyone know why this is happening. Im riding a Mod if that helps. ??? Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted September 5, 2009 Report Share Posted September 5, 2009 Are you running smooth snail cams? If so i would invest some some notched ones. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 5, 2009 Report Share Posted September 5, 2009 Tighten the wheel beter? Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted September 5, 2009 Author Report Share Posted September 5, 2009 No I'm running a shitty chain tug kind of device lol I'm now realizing that this is clearly the problem. But surely if the wheel was tightened then it shouldn't slip ? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 5, 2009 Report Share Posted September 5, 2009 No I'm running a shitty chain tug kind of device lol I'm now realizing that this is clearly the problem. But surely if the wheel was tightened then it shouldn't slip ?When you pedal ( kick ) the driveside of the wheel is wrenched forwards. The wheel won't hold itself, even if you cream the axle bolts, it needs soemthing to actually prevent it moving forwards hence cams/tugs. Quote Link to comment Share on other sites More sharing options...
