How Do I Make My V-brakes More Stronger?
Ashley Sayers
i dunno if its the pads , because when i press my back brake the lever dont spring back ?
Lol erm just on your brake make sure cable where it goes through to make the leaver arms come together tighten that bolt tight and set up the brake perfect and it should be ok and on your leaver make sure the cable is in the leaver properly.
Danny :)
I would buy new lever like avid sd 7,onza v brake calipers aren´t that bad i guess.And about the pads,are they clear ones or black?Try to use a little bit of tar,it´s easier than grinding rim and it helps a lot.And lube all cables!!!!
Edited by ghostrider88
is it that you dont like punctuation mate
Edited by Horndean Trials
