Lei ke si Posted September 4, 2009 Report Share Posted September 4, 2009 how to cut a tryall rim to make it Single wall..if i make to Single wall can i cut to square hole Quote Link to comment Share on other sites More sharing options...
daleyboy91 Posted September 5, 2009 Report Share Posted September 5, 2009 Just out of interest why do you want to try this?? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 5, 2009 Report Share Posted September 5, 2009 how to cut a tryall rim to make it Single wall..if i make to Single wall can i cut to square holeRight, so to single-wall my echo rim i used:4" angle grinder with thin metal cutting disc ( 2-4mm )flat filecoarse sand paper ( 100 grit ~ )fine sandpaper ( 200 grit ~ )Put the wheel in a pair of forks/frame; now get someone to hold he opposite side of the wheel and to help turn it. Start cutting on one side of the inner skin, make a half depth cut all the way around the wheel on one side, then do the other side half-way through as well. Make the final cut on the first side all the way through the skin, i made around 8 diagonal cuts across the skin so the inner wall came out as several pieces, not just one continous strip. Now cut all the way through on the second side. Finish up by removing any large protrusions with the grinder.Note: Care must be taken not to hit the small lump near the braking surface, its a hollow structure, that is quite important to strucural integrity.the rough cut rim now has to be de-burred with the file, using long strokes and concentrating on any really rough areas, go around the whole room removing scurf until its all fairly even, and you can run a piece of tiolet/tissue paper around the cut edge without it snagging.I then finished it off with the heavy grade sand paper to give a clean finish , then used the fine grade to get it pretty much completely smooth.A reasonable amount of skill with a grinder is needed, along with a fair bit of patience.From start to finish this took me around 45mins for a front dual wall echo 07 rim. That wheel has been ruin for around 7 months with no punctures as yet.Any more help needed, just PM me...im singlewalling another echo rim quite soon so im sure i can help Just out of interest why do you want to try this??To save weight....and remove unnecesscary material. Also saves a fair whack of money compared to buying one of the new fancy Hole rims. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 5, 2009 Report Share Posted September 5, 2009 Right, so to single-wall my echo rim i used:4" angle grinder with thin metal cutting disc ( 2-4mm )flat filecoarse sand paper ( 100 grit ~ )fine sandpaper ( 200 grit ~ )Put the wheel in a pair of forks/frame; now get someone to hold he opposite side of the wheel and to help turn it. Start cutting on one side of the inner skin, make a half depth cut all the way around the wheel on one side, then do the other side half-way through as well. Make the final cut on the first side all the way through the skin, i made around 8 diagonal cuts across the skin so the inner wall came out as several pieces, not just one continous strip. Now cut all the way through on the second side. Finish up by removing any large protrusions with the grinder.Note: Care must be taken not to hit the small lump near the braking surface, its a hollow structure, that is quite important to strucural integrity.the rough cut rim now has to be de-burred with the file, using long strokes and concentrating on any really rough areas, go around the whole room removing scurf until its all fairly even, and you can run a piece of tiolet/tissue paper around the cut edge without it snagging.I then finished it off with the heavy grade sand paper to give a clean finish , then used the fine grade to get it pretty much completely smooth.A reasonable amount of skill with a grinder is needed, along with a fair bit of patience.From start to finish this took me around 45mins for a front dual wall echo 07 rim. That wheel has been ruin for around 7 months with no punctures as yet.Any more help needed, just PM me...im singlewalling another echo rim quite soon so im sure i can help To save weight....and remove unnecesscary material. Also saves a fair whack of money compared to buying one of the new fancy Hole rims.That bit made me laugh Alex but not in a bad way.Matt Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted September 6, 2009 Author Report Share Posted September 6, 2009 can I use saw to cut the inner wall..I make the hole to Big now I can see the hollow part will it spoil.. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 7, 2009 Report Share Posted September 7, 2009 That bit made me laugh Alex but not in a bad way.Matthaha im not suprised...adn it WAS typo....only jakes singlewall attempt failed, mines still going strong check jakes attempt herecan I use saw to cut the inner wall..I make the hole to Big now I can see the hollow part will it spoil..erm i'd advise using a grinder, what sort of saw are you planning on using? erm, how big are the holes? pictures would be a help Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted September 7, 2009 Author Report Share Posted September 7, 2009 I using a small hex saw I s it ok Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 8, 2009 Report Share Posted September 8, 2009 I using a small hex saw I s it okErm, never heard of that Sure you don't mean hacksaw? Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted September 9, 2009 Author Report Share Posted September 9, 2009 I think so is a small saw Quote Link to comment Share on other sites More sharing options...
