broggers Posted September 2, 2009 Report Share Posted September 2, 2009 looking at getting a set of brakes. looking at the magura hs33 any good for trialsi will have them front and rear. good setup choice?. How much will i have to spend for second hand set in the flurescent green/yellow colour or is it just worth buying newcheers broggers Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 2, 2009 Report Share Posted September 2, 2009 Just get some of the new style ones second hand off here or ebay And will you be running a grind or smooth rim? Quote Link to comment Share on other sites More sharing options...
Sammyturbo Posted September 2, 2009 Report Share Posted September 2, 2009 looking at getting a set of brakes. looking at the magura hs33 any good for trialsi will have them front and rear. good setup choice?. How much will i have to spend for second hand set in the flurescent green/yellow colour or is it just worth buying newcheers broggersVery good choice for trials mate not sure how much you would have too spend but a quick look on the for sale section will tell you Quote Link to comment Share on other sites More sharing options...
broggers Posted September 2, 2009 Author Report Share Posted September 2, 2009 Just get some of the new style ones second hand off here or ebay And will you be running a grind or smooth rim?i was looking at smooth rims im pretty new to this game which is better?good idea will look in the for sale section Quote Link to comment Share on other sites More sharing options...
josh barker Posted September 2, 2009 Report Share Posted September 2, 2009 i was looking at smooth rims im pretty new to this game which is better?good idea will look in the for sale sectionHi, what you would want is a disc on the front (magura louise, avid bb5-7, hope mono trial etc). as hs33's on the front can crack your forks due to them being just so powerful!. hs33 on back with a 4 finger lever blade a metal tpa wheel as the plastic ones are well known for rounding off the threads and some good pads that work well on a grind then it will be a beast! Quote Link to comment Share on other sites More sharing options...
Ali C Posted September 2, 2009 Report Share Posted September 2, 2009 hs33's on the front can crack your forks due to them being just so powerful!.its not really the power that cracks the forks, its more due to the brake mounts being welded to the fork where they flex the most causing a stress riser. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted September 2, 2009 Report Share Posted September 2, 2009 If your going for smooth rims, get some Heatsink yellows.But if you want to ride in when its a bit wet get a grind and some try all/koxx browns Quote Link to comment Share on other sites More sharing options...
broggers Posted September 2, 2009 Author Report Share Posted September 2, 2009 Cheers for the advice guys really good help. Was thinking about hope disk on the front seems to be the most common thing v on the back disk on the front. Is there any cheap maguras in the for sale section as im pretty sure i cannot post there yet?I doubt ill ride in the wet. Bit of a fair weather rider.The rims i am currently using are a set of 24" halo combats, tad heavy but look good broggers Quote Link to comment Share on other sites More sharing options...
ashleysmith Posted September 2, 2009 Report Share Posted September 2, 2009 broggers add me on msn i may be able to help you Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 3, 2009 Report Share Posted September 3, 2009 add me to msn also Quote Link to comment Share on other sites More sharing options...
broggers Posted September 3, 2009 Author Report Share Posted September 3, 2009 add me to msn also Sorry lads dont have msn any other way my email address is wrx_277@hotmail.co.uk Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted September 4, 2009 Report Share Posted September 4, 2009 its not really the power that cracks the forks, its more due to the brake mounts being welded to the fork where they flex the most causing a stress riser.Unless they are on the back.Also as Ali often says V brakes front and back is win/win.(Says Matt that now has maggies front and back- )My kids bike has Avids front and back and it just gives you a different lighter feeling when your riding, but I'm sticking with my maggies because I can just ride his when I feel like riding Vees. Matt Quote Link to comment Share on other sites More sharing options...
