Andrew C Posted September 2, 2009 Report Share Posted September 2, 2009 I was just wondering if enyone on here has a marino 20" and if it is stiff, strong, what weight it is and how long it takes to be posted.I need a new (cheep) frame with a good geo and i think it would be a good option cheers. Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 2, 2009 Report Share Posted September 2, 2009 Stiff, well, as they're steel, it's bound to be less stiff than a similar alu frame.Strong, Mr. Marino seems to be getting welding down, so it should be pretty good. Being steel it's also very easy to get repaired if it breaks.Weight, depends on what you order really, but as it's steel, it's likely to be heavier than a similar alu frame.Postage, a week or two, I think. Quote Link to comment Share on other sites More sharing options...
Andrew C Posted September 2, 2009 Author Report Share Posted September 2, 2009 Stiff, well, as they're steel, it's bound to be less stiff than a similar alu frame.Strong, Mr. Marino seems to be getting welding down, so it should be pretty good. Being steel it's also very easy to get repaired if it breaks.Weight, depends on what you order really, but as it's steel, it's likely to be heavier than a similar alu frame.Postage, a week or two, I think.Thanks for that but i would really like to know the weight like say you got a geo the same as an onza blade do you reckon it will weigh less than 2kg ?Sorry for all the questions but im confuessed on what frame to get thanks? Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted September 2, 2009 Report Share Posted September 2, 2009 Thanks for that but i would really like to know the weight like say you got a geo the same as an onza blade do you reckon it will weigh less than 2kg ?Sorry for all the questions but im confuessed on what frame to get thanks?Yeah i think it should! Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 2, 2009 Report Share Posted September 2, 2009 Yeah i think it should!Marinos are steel, steel is heavier than alu. Steel tubing is thinner and it still works out heavier. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 3, 2009 Report Share Posted September 3, 2009 Marinos are steel, steel is heavier than alu. Steel tubing is thinner and it still works out heavier.would have thought that frame would be around.....2.3kgs maybe? Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 3, 2009 Report Share Posted September 3, 2009 Mmm, and the blade frame is 1.5 Get one made, there's no reason not to. Have a good look at the geometry you want though. Remember, you can choose the geometry of any other frame out there, or even your own. Quote Link to comment Share on other sites More sharing options...
Andrew C Posted September 5, 2009 Author Report Share Posted September 5, 2009 How much will it cost for a 20" disc frame ? Quote Link to comment Share on other sites More sharing options...
indianatrials Posted September 5, 2009 Report Share Posted September 5, 2009 Im 99% sure he said 120usd for the frame and plus 100usd shipping. Im to lazy to convert it for you. They wey from 2.1kg to 2.3kg i do know that for sure. Quote Link to comment Share on other sites More sharing options...
Andrew C Posted September 5, 2009 Author Report Share Posted September 5, 2009 ok thanks Quote Link to comment Share on other sites More sharing options...
ScottTrials Posted September 5, 2009 Report Share Posted September 5, 2009 Im 99% sure he said 120usd for the frame and plus 100usd shipping. Im to lazy to convert it for you. They wey from 2.1kg to 2.3kg i do know that for sure.You might not off done it but i sure did as I want a marino 20". there £140 posted to the uk Quote Link to comment Share on other sites More sharing options...
Andrew C Posted September 5, 2009 Author Report Share Posted September 5, 2009 You might not off done it but i sure did as I want a marino 20". there £140 posted to the ukCool yhea i worked it out yearlyer but thanks enyway and thanks for the help guys Quote Link to comment Share on other sites More sharing options...
indianatrials Posted September 5, 2009 Report Share Posted September 5, 2009 No problem. E-mail him to check prices, im sure shipping will be a tad more as your across the pond. Quote Link to comment Share on other sites More sharing options...
