Tensile 60 Click
tvee rider
im changing my tensile to a try-all 108.9, because just getting fed up of it skipping all the time.
but if you do want a tensile id recommend the new one that tartybikes has just got in here: http://www.tartybikes.co.uk/product.php?product_id=10937
I tell you what, instead of buying a expensive freewheel that is garenteed to explode! Why not undo the lockring on your tensile and give it a quick squirt with GT85 or someting simular or if your confident with taking stuff a part totally strip it down give it a proper clean and a dab of lube lockring back on nice and tight it should feel brand new agian and save you cash and your face!
The old tensile's freewheels are amazing, Going to a try-all is a big mistake from reading the reviews upon them, As liam said simply take you're tensile apart clean re-grease you might need new paws or spring's tarty stock them. And put it back together.
I've heard enough bad things about tensiles and try-alls to stick with an ENO. I'm not saying they're bad freewheels, but ENO's are soooo god damn good.
The main thing is maintenance with a free wheel if its worn or damaged it can either be fixed or replaced.
There is alot of wear an tear put on a free wheel so keeping it clean internally an nicely lubed an you shouldn't really have a problem.
cheers
Ben
already had a eno after 2mins of riding the lockring had come lose then the lockring came off and lost the pawls and springs so had to put tensile back on
what are the echo sl ones like?
I think you're the only person who has ever managed to do that. :lol:
