Front Disc Brake Cable
LukasMcNeal
Anyone know a good Front disc brake cable for about/ under a tenner that will be the right size without cutting it down because when I cut it, it always frays.
If it helps Ive measured and about 28-30" or 71-76cm seems about the right size.
Get better cutters, put a cable end on it, so it does not fray - problem solved.
