seaine Posted August 27, 2009 Report Share Posted August 27, 2009 hi i am building a new bike and i was wondering what people have as a front brakewhats the advantage of discs over maguras or v brakesi perfer v brakes as you can control the feel of the alot easier than discs or maguras easier but thats just mei have a set of vees already for it.they are single 7s.i see alot of bikes have discs now but i dont see many front maguras or vees anymorejust wondering what the people on here use and why? Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 27, 2009 Report Share Posted August 27, 2009 Discs offer better modulation, I think. Plus if you go to front and buckle your wheel, the magura will need re-setting up.A good disc like a BB7 or a hope moto trials will do you well. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 27, 2009 Report Share Posted August 27, 2009 Magura is still a good option. Good hold and lock depending on pads and also the authentic trials sound when braking. In a way some discs are crap and some maggys are crap such as discs can go wrong and maggys can too but , Magura can also be easily bled without anything except for a bucket and most of the time in the long run maggys are cheaper. Quote Link to comment Share on other sites More sharing options...
Muel Posted August 27, 2009 Report Share Posted August 27, 2009 Plus if you go to front and buckle your wheel, the magura will need re-setting up.A good disc like a BB7 or a hope moto trials will do you well.they're called Mono Trial, not moto trials. You don't need to reset the magura either, you need to true the wheel.Magura is still a good option. Good hold and lock depending on pads and also the authentic trials sound when braking. In a way some discs are crap and some maggys are crap such as discs can go wrong and maggys can too but , Magura can also be easily bled without anything except for a bucket and most of the time in the long run maggys are cheaper.I find when discs go wrong it's far easier to work out what is wrong.Discs are easier to bleed than Maguras if anything! Unless you're using a pure water bleed. (Which doesn't lubricate the seals enough IMO). Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 27, 2009 Report Share Posted August 27, 2009 (edited) I find when discs go wrong it's far easier to work out what is wrong.But for maggys all it is usually another bleed or at the most lube the slaves. Edited August 27, 2009 by LukasMcNeal Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 27, 2009 Report Share Posted August 27, 2009 I just recently went to front maggies.My reason is that I don't want to smash my disc up on sidehops, had a formula disc and it was far to nice(and expensive) to go smashing up.May go back to disc once I have sidehops dialed nicely but I am loveling maggies at the minute, less weight as well!Matt Quote Link to comment Share on other sites More sharing options...
seaine Posted August 27, 2009 Author Report Share Posted August 27, 2009 maguras are lighter than a disc brake???? Quote Link to comment Share on other sites More sharing options...
hdmackay Posted August 27, 2009 Report Share Posted August 27, 2009 maguras are lighter than a disc brake????Yes, by quite an amount. Quote Link to comment Share on other sites More sharing options...
seaine Posted August 27, 2009 Author Report Share Posted August 27, 2009 you?? I never noticed the difference it the weight.Do many people use v brakes anymore,have not seen many around. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted August 27, 2009 Report Share Posted August 27, 2009 you?? I never noticed the difference it the weight.Do many people use v brakes anymore,have not seen many around.yeh there was a bit of a trend for them recently.... Quote Link to comment Share on other sites More sharing options...
Mr Bob Posted August 27, 2009 Report Share Posted August 27, 2009 I donnt like my hope disc brake much, go dual maggura or vee Quote Link to comment Share on other sites More sharing options...
josh barker Posted August 27, 2009 Report Share Posted August 27, 2009 but maggies can crack your forks i prefer my magura louise more, my choice is disc all the way Quote Link to comment Share on other sites More sharing options...
chiefy Posted August 27, 2009 Report Share Posted August 27, 2009 My mono trial i find it to be a good brake. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 28, 2009 Report Share Posted August 28, 2009 Magura is still a good option. Good hold and lock depending on pads and also the authentic trials sound when braking. In a way some discs are crap and some maggys are crap such as discs can go wrong and maggys can too but , Magura can also be easily bled without anything except for a bucket and most of the time in the long run maggys are cheaper.just get a good cable, eg. BB7 Don't need bleading, and are powerfull Quote Link to comment Share on other sites More sharing options...
tvee rider Posted August 28, 2009 Report Share Posted August 28, 2009 Magura louise whole brake for sale £40 anyone good condition and i know i am not ment to post this but oh well ?? Quote Link to comment Share on other sites More sharing options...
hdmackay Posted August 28, 2009 Report Share Posted August 28, 2009 but maggies can crack your forks i prefer my magura louise more, my choice is disc all the wayDiscs can crack your forks too. Just not as quickly. Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted August 30, 2009 Report Share Posted August 30, 2009 Magura HS33 are definitely my favourite brake.They don't have as good modulation as disk brakes but they have much better stopping power.They are also a lot easier to maintain and set up. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 30, 2009 Report Share Posted August 30, 2009 Magura HS33 are definitely my favourite brake.They don't have as good modulation as disk brakes but they have much better stopping power.They are also a lot easier to maintain and set up.Un till you buckle your rim Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted August 30, 2009 Report Share Posted August 30, 2009 Un till you buckle your rim Well a spoke key only costs like £5. But yeh... They can be hard to set up if your wheel is buckled. Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 30, 2009 Report Share Posted August 30, 2009 ok its clear the difference between front disk and a rim brake, but please someone tell me the advantages of a front maggie over a vee?I can think of one: Sealed unit so less maintanence (although I am still on the origional cable I fitted 4 months ago)And advantages of a vee over magura??LighterMore powerMore adjustableeasier to get replacementsDoesn't break forksPossible to remove the wheel without deflating the tyrePads wear evenly and therefore last longereasier to setup. I WILL get people to see the light and buy a vee rather than magura Quote Link to comment Share on other sites More sharing options...
hdmackay Posted August 30, 2009 Report Share Posted August 30, 2009 (edited) ok its clear the difference between front disk and a rim brake, but please someone tell me the advantages of a front maggie over a vee?I can think of one: Sealed unit so less maintanence (although I am still on the origional cable I fitted 4 months ago)And advantages of a vee over magura??Lighter - Couldn't care less.More power - No! No way. Haha. With a grind and or tar and good pads a magura is wayyy more powerful!More adjustable - How?easier to get replacements - How!?Doesn't break forks - That means it aint as powerful then. Possible to remove the wheel without deflating the tyre - Ok. One up there.Pads wear evenly and therefore last longer - If you set Magura pads up perfect they wear evenly,easier to setup. - Well, I find Magura's sooo easy to set-up. When I used to have a vee I found it soo annoying to set upI WILL get people to see the light and buy a vee rather than magura I'm afraid I will always be for maggies. I mean I wouldn't mind a front vee. But ALWAYS rear mag. And usually front mag aswell.Hehe. Edited August 30, 2009 by hdmackay Quote Link to comment Share on other sites More sharing options...
Mr Bob Posted August 30, 2009 Report Share Posted August 30, 2009 i must admit im very tempted to run a vee on the front, to many problems with my hope. what pads do you rin in the vee and do you run front and rear ali? Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 30, 2009 Report Share Posted August 30, 2009 I know it will be hard to make people change, to be honest it doesn't bother me that much, but I just don't see the logic of having front magura (or rear lol, I am never having a maggie again!) Quote Link to comment Share on other sites More sharing options...
hdmackay Posted August 30, 2009 Report Share Posted August 30, 2009 (edited) I know it will be hard to make people change, to be honest it doesn't bother me that much, but I just don't see the logic of having front magura (or rear lol, I am never having a maggie again!)Haha. Well. I love my maggies.I may consider front vee for a while just to see what you love so much. Haha. But NEVER rear vee! haha.EDIT: Ali, you did read my answers to the bit in your original post about vee advantages right?Think i'll put them in bold:PEDIT 2: Done:) Edited August 30, 2009 by hdmackay Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 30, 2009 Report Share Posted August 30, 2009 Lighter - Couldn't care less.More power - No! No way. Haha. With a grind and or tar and good pads a magura is wayyy more powerful!I'll have you know that Vee brakes in medium setting is roughly 10% more mechanically powerful than a MaguraMore adjustable - How? Avid SD7 levers have a TPA adjustment AS WELL as power adjustment, you can also adjust each arms springs while riding without tools (handy if you get a buckle)easier to get replacements - How!?Most bikeshops in the world carry vee brake parts, you can even get cables in supermarkets!Doesn't break forks - That means it aint as powerful then. wink3.gNarr, its due to a smaller weld area on the forks which doesn't make such a stress riser.Possible to remove the wheel without deflating the tyre - Ok. One up there.Pads wear evenly and therefore last longer - If you set Magura pads up perfect they wear evenly,They still wobble and get rounded ends thougheasier to setup. - Well, I find Magura's sooo easy to set-up. When I used to have a vee I found it soo annoying to set up2 bolts to mount the brake, pull cable though and tighten pinch bolt, took me moments to fit my front brake. Quote Link to comment Share on other sites More sharing options...
