M4RK1992 Posted August 26, 2009 Report Share Posted August 26, 2009 hi there please, please. please help me.. i have a onza t pro 07 and the rear wheel moves out of line slightly all the time and the chain comes loose. i keep tightening it up and it keeps doing it. its really testing me now,i cant see what the problem is. i am usin chain tugs by the way. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted August 26, 2009 Report Share Posted August 26, 2009 Get snail cams. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 26, 2009 Report Share Posted August 26, 2009 You tightening the tugs a bit each time? then tightening the wheel bolts? Quote Link to comment Share on other sites More sharing options...
M4RK1992 Posted August 26, 2009 Author Report Share Posted August 26, 2009 i have some monty ones but they dont reach to the snail cam bolt. i have just brought these hoping these ones will reach.. http://www.tartybikes.co.uk/product.php?pr...category_id=114and yes i tighten each tensioner and then tighten the wheel bolts. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 26, 2009 Report Share Posted August 26, 2009 V!Z will fit if Monty are too small, as V!Z are hugee.But do the bolts uo tighter on the wheel Quote Link to comment Share on other sites More sharing options...
M4RK1992 Posted August 26, 2009 Author Report Share Posted August 26, 2009 ok lets hope they do fit. thanks for your help. and i have been doing the bolts up extremely tight. is there any technique or easy way to get your wheel to stay in place with snail cams? Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 26, 2009 Report Share Posted August 26, 2009 Just fit them, get the tention in the chain to the amount you want, then tighten the bolts. Quote Link to comment Share on other sites More sharing options...
M4RK1992 Posted August 28, 2009 Author Report Share Posted August 28, 2009 right i got my new snail cams. i tension the chain up and get the wheel inline.. and then i will do a few kick hops and the chain comes loose but the wheel is still inline? what the hell is going on? i will be very gratefull for some good advice and some help. Quote Link to comment Share on other sites More sharing options...
M4RK1992 Posted August 28, 2009 Author Report Share Posted August 28, 2009 please help. im sure someone knows or has had the same problem before? thanks Quote Link to comment Share on other sites More sharing options...
ashleysmith Posted August 30, 2009 Report Share Posted August 30, 2009 pop it over to broadribbs cycles in leam and come and see me.... might be able to help Quote Link to comment Share on other sites More sharing options...
callumbreakwell85 Posted August 30, 2009 Report Share Posted August 30, 2009 right i got my new snail cams. i tension the chain up and get the wheel inline.. and then i will do a few kick hops and the chain comes loose but the wheel is still inline? what the hell is going on? i will be very gratefull for some good advice and some help.Your chain may be stretching. Is it a brand new chain? Quote Link to comment Share on other sites More sharing options...
Sam Moss Posted September 1, 2009 Report Share Posted September 1, 2009 I have the same problem actully but i have snail cams. I just leave it because my chain doesn't skip and nothing is wrong. Quote Link to comment Share on other sites More sharing options...
WIGAN Posted September 1, 2009 Report Share Posted September 1, 2009 you sure you dont just have a lot of float in your freewheel, rotate your cranks to several different positions then check it? if not then maybe your bearngs are dead in the back ?? Quote Link to comment Share on other sites More sharing options...
