Forks Ringing
Kieran
Alright,
I have Echo Lite forks from '07 and im running a front mag with heatsink whites. My brake is amazing and also really loud although my forks make an annoying ringing sound when i use my front brake. Any suggestions on how to stop it or are echo forks just like that?
Cheers,
Kieran
Kieran, I don't think it's that big a deal but I suppose it's wierd how it happens to yours but no-one elses.
Tighten headset
That could be your problem right there. His headset is super loose. And always will be until he gets another stacker/ cuts down his steerer tube. :P
i dont think there is anything you can do about it as its just the forks natural resonating
Doesn't happen to anyone elses though and most of the people we ride with have those forks.
EDIT: Mat Smith's point could be quite valid. (N)
Just hope they aren't cracked. :glare:
Edited by hdmackay
Check for cracks.
Checked them for cracks today with Hunter, also tightened my headset. Didnt find any at all and the forks are only like 3 months old, maybe not even that. The ringing is probably because of the bolts i have, still got the total short Magura bolts and there so close to rounding that i'm scared to tighten them. I'll get new bolts and see if the ringing stops.
Checked them for cracks today with Hunter, also tightened my headset. Didnt find any at all and the forks are only like 3 months old, maybe not even that. The ringing is probably because of the bolts i have, still got the total short Magura bolts and there so close to rounding that Hunter's scared to tighten them. I'll get new bolts and see if the ringing stops.
:P>_<
Have you got a grind on your rim? If so it could be pads resonating through the slave cylinders and passing through to the forks the vibrations causing sound. It happens with v brakes and discs too. Nothing to worry about!
Nah, he doesn't have a grind.
