maxxis26 Posted August 22, 2009 Report Share Posted August 22, 2009 (edited) right been trying to setup my hope mini for a while now and whatever i do it just keeps rubbing the diskany advice on seting it up or will it always rub?setup ishope lx hub o6 hope mono mini 160 saw rotorecho forkany help? Edited August 22, 2009 by maxxis26 Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 22, 2009 Report Share Posted August 22, 2009 Have you tryed to put half mm washer inbetween the forks and the caliper? (if it is rubbing on the right handside pad)If its rubbing on the left hand sidepad the forks might have to be re-faced, not too sure but im positive somebody will correct me. Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted August 22, 2009 Author Report Share Posted August 22, 2009 ive tried various washers and no resulthadnt thought about re facing the disk mount though Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 22, 2009 Report Share Posted August 22, 2009 Think that could be the best bet then. Quote Link to comment Share on other sites More sharing options...
r2wtrials Posted August 22, 2009 Report Share Posted August 22, 2009 Get it re-faced, that way at least you are starting with it sitting square. Then if it rubs you can use shim washers.On a similar note, i have a try-all rotor and it is actually 3 mm or so over size. I had to use by bench grinder to get it to stop rubbing on my 180mm Hope set-up. It was hitting the top of the pad groove and not the pads... just make sure that isn't the case with yours. Quote Link to comment Share on other sites More sharing options...
