Bottom Bracket Question .
Mission Prodigy Trials.
Hello Trials-Forum Members I have recently fitted a Bottom bracket to my Brand new Gu-st frame but I think I have put it on the wrong way, :unsure:
So I am wondering if it would affect the bikes performance or anything .
The Left side is next to my Front Freewheel and Right crank arm, It should be on R ..
The biggest end of that bb goes on the drive side, the flatish bit none drive side, usually the bit you can pull out easily goes on the none drive side, and the really stiff bit goes on the drive side.
Ok, Thankyou for the Advice ...
So shall I just keep it as it is or will it cause problems in the future . ?
